ford nine inch confusion - Page 2 - Ford Truck Enthusiasts Forums
Old 12-30-2008, 10:12 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
in this pic you'll see how much the axle shaft goes inside before it reaches the bearing retainer. more axle shaft inside, means less axle tube outside. for an even length axle shaft for both sides.
The view of the third member is upside down.
Old 12-30-2008, 10:31 PM
woodyf1's Avatar
woodyf1 woodyf1 is offline
woodyf1 is starting off with a positive reputation.
yup 40 inches all is good check my reply on other thanx havi
Old 12-31-2008, 10:41 PM
bememe bememe is offline
bememe is starting off with a positive reputation.
Just so you are aware you can have a 9" built with the pinion centered. Currie did mine for me, and all cuz I just can't stand looking at the driveshaft shooting off to one side. I guess I'm symmetrical like that. That and I wanted 31 spline axles too. Oh and I forgot I needed to change the wheel pattern to 5 X 4.5.
Old 12-31-2008, 11:28 PM
havi's Avatar
Yep, Currie is well known for making 9" rears. Moser makes them too.
Old 02-02-2009, 01:09 PM
rockher_man's Avatar
rockher_man rockher_man is offline
rockher_man is starting off with a positive reputation.
Question late to the party...
Quote:
Originally Posted by AXracer View Post
One direction or the other or both needs to be offset for the driveshaft U joints to work properly. A perfectly straight driveshaft thru the centerline of the engine and rear axle pinion will tear up the U joints in short order.
So IF I understand this correctly...the offset left-to-right is kool with
the pinion angle at 2-3 degrees on this 9" picture...and my u-joint sould live thru it...theroretically...
...'cause the one I settin' up for my '56 looks kinda just like it outa a '70 effie...am i on the same page???......
You folks have been ALOT of help so far......THANX...
Old 02-02-2009, 06:46 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I can't tell from the picture, but if the left and right side of the rear axle are different lengths from the axle flanges to the pinion, that's cool as long as you position the engine with the crankshaft centerline parallel to the frame. Do not offset the engine in the frame to match the pinion offset. (you can offset the engine side to side in the frame if needed for starter or steering box clearance, just don't offset it an equal amount to the pinion offset) If you mount the engine with a downwards tilt to the tranny end when viewed from the side (normally this will be the case when matching the factory orientation of the carb flange on the intake being set level with the ground), then the rear axle rotation (pinion angle) should match that angle.
I will be adding a diagram to this post for clarification shortly, stay tuned!
Old 02-02-2009, 09:43 PM
Red face Ok...
Me thinks me got it...ugh...
Old 02-03-2009, 03:21 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Any ID numbers on the carrier (pumpkin) like C2AW, C6AW, C7AW?
Just to let you know, there were TWO different 9" rear ends used in 1968/72 F100's.
One has a 9" ring gear with 28 splined axles, one has a 9 3/8" ring gear with 31 splined axles.
The only parts that interchange between the 9" and the 9 3/8" are the 2 pinion bearings and one race.
Everything else is different including the seals.
E40D transmission/Ignition problem...Any advice would help FoMoCoFan52 1987 - 1996 F150 & Larger F-Series Trucks 13 04-03-2015 06:16 PM
Power Steering Difficult Only In One Direction (Right) hurstcastle 1967 - 1972 F-100 & Larger F-Series Trucks 16 01-06-2008 03:44 PM
Shocked an Appalled... 1FineBroncoBabe General NON-Automotive Conversation 79 03-04-2006 04:09 PM
Merry Christmas 3broncocrazy Georgia Chapter 5 12-25-2005 01:58 AM
I lurk no more.. 92 F150 Owner honeydo New Member Introductions 1 10-21-2004 04:40 PM
Tags
9, axle, body, confusion, ford, fox, length, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
