Brake lines..
Brake lines..
So i have a 1972 f100 long box that needs some brakes. It has been lifted and looks like someone tried to do custom brakes??.. They have a splitter on the front and rear axle that branch off to each wheel..(one line to the back that splits, and one to the front the splits) Does that sound right?? Plus I work at a junk yard and we have numerous Fords from the 80's but not so anything before that...
So my question should i just try to make some new ones?? Or would any lines from the 80's trucks be legit to use?? Oh and is the one brake line to each axle that splits safe or should i have that redone??
Tyger, If you will be doing a disc upgrade in the near future you will use a line to each front wheel with a single line to a splitter on the rear. The brake lines are like any other plumbing, they hold the fluid that moves the plunger that moves the shoes.
I have never heard of any legal issues concerning brake lines, other than you must have them.
What's your plan for the truck?
John
John
The system you have is exactly the way it came from the factory.
Am I misled thinking proportioning valves were only used on disc/drum sets?
John
On the proportioning valve question, yes, you were misled. A split (dual line) 4 wheel drum brake systems used a proportioning valve.
ulfie
11-13-2016 08:33 PM
Dashknob
04-16-2015 10:17 PM
