300 exhaust manifold plate
Old 12-29-2008, 02:51 PM
southpole512's Avatar
southpole512
southpole512 is offline
'66 F-100, 300 I-6
Does anyone know where to get a replacement plate for the exhaust manifold riser (not the riser valve, but the plate above it)? Are they available or do I need to have one fabricated. Mine is warped.
Old 12-29-2008, 03:13 PM
SJ Bikesaws's Avatar
SJ Bikesaws
SJ Bikesaws is offline
Are you talking about the EGR (exhaust gas re-circulation) spacer under the carb?
Old 12-30-2008, 07:53 AM
southpole512
I'm not sure. Below the carb, there is a space (approx. 3/4") between the intake manifold and the exhaust manifold. The exhaust manifold had a bolted on plate (approx. 3/16" thick) just below the carb (rusted and warped). Under the plate (in the ex. manifold) you can see where the riser valve used to be (removed and holes filled in). Since the plate is warped, exhaust gases, and noise, are spilling out in the engine compartment.
Thanks.
Old 12-30-2008, 10:23 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1965/70 F100/600 240/300 Carburetor Spacer Plate / 1965/69 Econoline
Originally Posted by southpole512
'66 F-100, 300 I-6
C5AZ9A589A .. Carburetor Spacer Plate to Intake Manifold / Obsolete
Fits 240/300 I-6's: 1965/70 F100/350 / 1965/70 F600 (w/o governor) / 1965/70 B/C/N/T500/600 (w/o governor) / 1965/70 P350/500 / 1965/71 Galaxie/LTD / 1965/69 Econoline.
How many would you like?
Obsolete parts vendor Green Sales Co. in Cincinnati OH has 151 = 800-543-4959
AAA Obsolete Ford Parts in Howe TX has 4 = 903-546-0024
Don Sanderson Ford in Glendale AZ has 30 = 623-842-8762
JST Automotive in Lebanon TN has 4 = 615-443-3086
There are 48 more scattered across the US at Ford dealers and obsolete parts vendors.
SJ Bikesaws: There were no EGR valves installed on any Ford car or truck until 1973.
Old 12-30-2008, 03:08 PM
southpole512
I appreciate the help, but just want to make sure I got this right. The plate I'm looking for bolts to the exhaust manifold. It does not go between the carb and the intake manifold. Is that the correct part number for the plate to the exhaust manifold?
Maybe my truck/engine has been modified. Is there anything that connects the exhaust manifold to the bottom of the intake manifold?
Thanks.
Vegas123
22
08-06-2019 12:18 PM
Feenba
08-13-2012 08:11 AM
highiron
08-08-2011 08:10 AM
ptmilan
11-23-2006 06:27 PM
Boomer95
02-23-2002 08:48 AM
Quick Reply: 300 exhaust manifold plate
