Where to buy new exhaust manifolds for a 302? - Ford Truck Enthusiasts Forums
Old 12-29-2008, 02:13 PM
460's Avatar
460 460 is offline
460 is gaining momentum as a positive member of FTE.
Is there anywhere that sells new exhaust manifolds for a 1978 F150 with a 302?
Old 12-29-2008, 02:47 PM
Casey_78 Casey_78 is offline
Casey_78 is starting off with a positive reputation.
LMC has manifolds for the 351M/400 for $129.95 each, however I don't know that they would work on a 302. Since the 302 and the 351 Windsor I believe are interchangable. Someone correct me if I'm wrong here.
Old 12-29-2008, 03:42 PM
460's Avatar
460 460 is offline
Yeah, I'm pretty sure the 351M/400 manifolds won't work.
I have some 351M/400 manifolds on the hunk of trash I pulled out, but now I need some 302 manifolds for the engine I put in.
The hunk of trash...
Old 12-29-2008, 05:05 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
I am sure Bill can get you OEM part numbers but you might try JBG they list them for all the other engines availible in these trucks except the 302 in the online catalog but I would call them and see if they list them for your application. Just one idea anyway, you might also check with your local ford dealer you never know.
Old 12-29-2008, 07:46 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
if your already replacing them, i would put headers on.
Old 12-29-2008, 07:59 PM
Is the truck 2wd? If so, I would switch to headers, otherwise if 4wd use the manifold.
Old 12-30-2008, 03:22 AM
460's Avatar
460 460 is offline
eh, I thought about headers, but I think they'll be more of an aggravation than they're worth. I'd use them if I can't find some cheap stock manifolds though.
I need oxygen sensor bungs welded in each side, and it would be a lot easier with manifolds because the exhaust guy can just put them in the pipes when he does the exhaust, and no wire harness extensions would be needed.
If I use headers though, I'd have to have the oxygen sensor bungs welded into the collectors, then I would need some extension harnesses for the sensors. It's possible that I would have to install the headers, then remove them to have the bungs welded, then put them back on... just depending on where the bungs need to go.
I'll be going to a junk yard soon, I may check there for something used... but used stuff is sometimes a headache too.
Old 12-30-2008, 04:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1973/79 F100/150 302 Exhaust Manifolds / 1973/77 Bronco
Quote:
Originally Posted by 460 View Post
.Is there anywhere that sells new exhaust manifolds for a 1978 F150 with a 302?
Both manifolds are obsolete...but there are a few new originals (NOS) still available.
D4OZ9431B .. Left Exhaust Manifold / Obsolete
Fits: 1973/79 F100/150 302 / 1973 Mustang 302 / 1973/74 Bronco / 1973/74 Torino 302 w/a M/T / 1977 Bronco.
Bob Allen Ford in Overland Park KS has FOUR: 800-676-0675
Kinsel L/M in Beaumont TX has FOUR: 800-816-2894
Obsolete parts vendor Green Sales Co. in Cincinati OH has ONE: 800-543-4959.
D5DZ9430A .. Right Exhaust Manifold / Obsolete
Fits: 1975/76 F100 302 / 1977/79 F100/150 302 / 1973/74 Econoline E100/300 302 (w/o a smog pump) / 1975/80 Granada/Monarch 302 (exc CA = DSO code with be 71 or 72) / 1975/77 Bronco.
Obsolete parts vendor Green Sales Co. in Cincinnati OH has TWO: 800-543-4959.
That's it. No other dealer or obsolete parts vendor has any of these manifolds NOS (New, Old Stock).
Since the Ford and L/M dealers are STUCK with them, the price should be somewhat reasonable, as they can no longer return them to Ford.
Casey_78: No 1969/79 F100's or 1975/79 F150's w/302's came with 4WD...all are 2WD.
Old 12-30-2008, 04:31 AM
460's Avatar
460 460 is offline
Excellent information, Bill! I don't know how you do it, but you truly are amazing
I'll give them a call later today, and hopefully I can get both from Green Sales Co. since they have at least one of each, but I'll check prices at the others for the left manifold to see who has the best price.
I think that manifolds should flow well enough for my stock 5.0 HO that I'm swapping in?
Old 12-30-2008, 05:05 AM
.Excellent information, Bill! I don't know how you do it, but you truly are amazing
Green Sales will be much higher in price than those two dealers will want for them, that I can assure you!
Usually when dealers are STUCK with anything that's obsolete, the selling price will (usually) be the dealers original COST price + 10%.
With Green, as with most of these obsolete parts vendors, the selling price will prolly be the original LIST price + who knows?
Will these manifolds flow the way you want them too? That I cannot say.
How do I do this? Piece of cake...as I have the parts catalogs, and two places online to search for parts...obsolete or not.
One is the in-house Ford dealer (only) parts locator system, the other is partsvoice.com, that anyone can use.
Old 06-26-2013, 05:59 PM
kuspie kuspie is offline
kuspie is starting off with a positive reputation.
I realize the post is 5 years old but I need a pair of the manifolds for a '79 F100 302. If you're still around the forum can you check availability? Thanks.
1993 F150 Exhaust Manifolds - Gaskets? jeff9942 1987 - 1996 F150 & Larger F-Series Trucks 18 09-27-2016 07:51 PM
Upper manifold support with aftermarket headers Glaser67 1987 - 1996 F150 & Larger F-Series Trucks 8 07-13-2016 07:24 AM
Flames out my exhaust manifold coleman12 1987 - 1996 F150 & Larger F-Series Trucks 6 11-04-2015 11:10 AM
Exhaust TO Manifold Bolt Blue50F-1 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-30-2013 10:41 PM
302 Exhaust manifold Dump port angle? quisp Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 03-18-2011 10:44 PM
Tags
1969, 197576, 302, 351c, 79, bronco, engine, exhaust, f100, fomoco, ford, manifold, manifolds, mustang, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
