Loud Squeal and thump under hood.
I have a 1997 F-250 with 7.3L diesel engine. Yesterday I started my truck and heard a loud squeal and light thumping under the hood. I raised the hood but could see nothing wrong. My initial thinking is that the water pump bearing is getting ready to go, although there is no visible leak and there is no play in the fan. All the internal gauges look good and there is not noticable decrease in performance or power. I don't want to drive it while it's making that noise so I'm trying to see if any of you more knowledgeable gentlemen can give me some recommendations.
Also, my truck was sold to me as a '97 but the plate in the door jamb says it was manfactured in December of 1997. Wouldn't that actually make it a '98?
Moby
Moby
If you have a 1998 OBS then you are the only person in the world that has one as Ford never made a 1998 OBS to my knowledge.
You might consider pulling the belt off and checking every inch if it the check all of the pulleys for freedom of movement.
You never said if the engine was still running when you were under the hood and if so could you still hear the noise/bumping.
Rog
Rog
or this one.
referrelative="t" o:spt="75" coordsize="21600,21600"><?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><Vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></Vath>fficeffice" /><v:imagedata o:href="http://photos.thedieselstop.com/data/3289/8810Q4235-B.gif" src="file:///C:\DOCUME~1\JAGJ\LOCALS~1\Temp\msohtml1\01\clip_im age001.gif"></v:imagedata><v:shape id=_x0000_i1025 style="WIDTH: 337.5pt; HEIGHT: 264.75pt" o:button="t" alt="Q4235-B" type="#_x0000_t75"><v:imagedata o:href="http://photos.thedieselstop.com/data/3289/8810Q4235-B.gif" src="file:///C:\DOCUME~1\JAGJ\LOCALS~1\Temp\msohtml1\01\clip_im age001.gif"></v:imagedata></v:shape>
Accessory Drive Belt, 7.3L Diesel Engine
1 Generator
2 Belt Idler Pulley
3 A/C Clutch Pulley
4 Vacuum Pump
5 Power Steering Pump Pulley
6 Crankshaft Pulley
7 Water Pump Pulley
8 Drive Belt Tensioner
9 Drive Belt<O></O>
1 Generator
2 Belt Idler Pulley
3 A/C Clutch Pulley
4 Vacuum Pump
6 Crankshaft Pulley
7 Water Pump Pulley
9 Drive Belt<O></O>
In my trials with belts and pulley's every time a pulley decided to go south the belt did not run straight causing it to fray on the rubbing side and boy did it make a heck of a sound-like a cat dying. The belt would not be frayed much at all. after finding the culprit if your belt is frayed it will need to be changed.
