Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-29-2008, 10:49 AM
v8xploder's Avatar
v8xploder v8xploder is offline
v8xploder is starting off with a positive reputation.
centech+efi+mass air?
I have the centech harness, I have a complete 5.0 efi harness out of an 88 stang. I will add mass air down the road. What problems should I be aware of in advance? Are they all compatable?
__________________
Cody
69 Bronco, 351W, Edelbrock performer, Holley 670 T/A 35'S 5.5'' Wildhorses lift, Locker rear, F-100 power steering and a slight rear main leak
92 Bronco Eddie Bauer, 351w, 31x10.50 No rust!!!
  #2 (permalink)
Old 12-29-2008, 12:14 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
that 88 stang harness should be mass air but if its not i have the mass air harness you would need to finish it up. If your interested PM me
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
JBA shorty, Custom Y pipe,3" exhaust
Warn HS9500I
installing soon: Edelbrock efi truck intake, aussie locker front/rear
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 12-29-2008, 03:16 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
Quote:
87 and 88 Federal were still speed density. Calif equipped only had MAF.
The harness should work just fine with your Centech. There are plenty of extra circuits to power the ECM.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #4 (permalink)
Old 12-30-2008, 09:21 PM
v8xploder's Avatar
Do you guys know if the 5.0 fuel rails and injectors will work on the 351 lower manifold? Or do I need the 351 fuel rail and injectors.....?
__________________
Cody
  #5 (permalink)
Old 12-31-2008, 06:19 PM
RCrawler's Avatar
The injectors are the same. I believe that the fuel rails will interchange as well.
Jason
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
