tensioner pulley???
Old 12-29-2008, 09:24 AM
StrokeThis96's Avatar
StrokeThis96
StrokeThis96 is offline
tensioner pulley???
was on my way home from christmas and my tensioner pulley broke off. i was just wondering the easiest way to get the tensioner pulley off. it looks like a simple take out the bolt and put the new pulley on. is the bolt on the pulley a right handed thread or is it normal and what size is it. just wonderin if someone could give me some info. thanks
Old 12-29-2008, 11:45 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
i would just spring for a new tensioner. They are more $$ but the peace of mind is good!
Old 12-29-2008, 07:46 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
X2 what he said, and remember
The bolt of the belt tensioner is right handed and I think is torx T50, and the bolt for the pulley of the belt tensioner is LEFT HANDED maybe 16 mm .
Old 12-29-2008, 08:25 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
I'd just replace it with a dual pulley tensioner from A SouperDooty.
Old 12-29-2008, 11:25 PM
nuke tech's Avatar
nuke tech
nuke tech is offline
Check NAPA. I replaced my tensioner with one from NAPA. It is a new design (different length).
Old 12-30-2008, 03:19 AM
joe_13894's Avatar
joe_13894
joe_13894 is offline
X2 on the new tensioner dual pulley.
I've always followed the advice that you should replace the tensioner if the belt ever falls off. They can be damaged when they snap open hard, and then fail a while later at the weak spot.
