Rear shock mount
Rear shock mount
The rear shock absorber mounting brackets are busted on my 1964 F100. I am talking about the bottom mount, which had been welded to the underside of the axle. The mounting brackets are in poor shape (thin metal), so I think welding them back is a poor option. Any ideas on how I can secure the rear shocks? Thanks!
Thanks John. The welding job was pretty pathetic. I am sure an experienced welder could do a much better job.
Do you know if an aftermarket mount is available? The current ones are pretty screwed up from the past welding effort. I could grind them down a bit and have a real welder attach them for me but a new mount would give him an better surface to work with. I've search arould some parts catalogues but haven't found anything.
Maybe I am making too big a deal out of this. I just got the car a week ago and she seems in pretty good shape except for the shocks being out of commission.
Ford never offered these lower shock mounts, they only were furnished with the axle housing.
According to the pics in the parts catalog, the type used on 1961/64 F100's is not the same as 1965/72 F100's used.
1961/64's have a pin (threaded on the end for the nut) that protrudes from the bracket that the shock mounts to.
1965/72's have two welded on straight brackets, the shock mounts between them using a separate bolt and nut.
Thanks to everyone who answered my question. I am going to have a friend try to weld the old mounts back to the axle. If that fails, we will fabricate new mounts.
I just found this site and I think it will be helpful to read all the old posts. I hope the group is willing to keep educating me if I have more questions.
Buckhorn2
06-12-2014 03:58 AM
raygussy
05-18-2007 02:25 PM
Olinger777
10-21-2002 04:51 AM
