Choke questions answered. - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-03-2010, 10:32 PM
kg4cna kg4cna is offline
kg4cna is starting off with a positive reputation.
Smile
Excellent thread! Thanks to this, I was able to understand how the hot air choke works. Mine is the electric assist version and is on a 73 Gran Torino with 302 and stock carb. Picked up a HELP! kit (at local auto parts store) with new tubing and fittings to replace the old one on mine.
Thanks!
Allen
  #32
Old 12-04-2010, 11:23 PM
73' f-100 73' f-100 is offline
73' f-100 is starting off with a positive reputation.
Thanks for the info on this. I see there are some more things that I need to get that I was thinking were not necessary.
  #33
Old 01-12-2011, 11:39 AM
kraylake's Avatar
kraylake kraylake is offline
kraylake has a good reputation on FTE.kraylake has a good reputation on FTE.
i know his is an old post (2004) but i looks like jus waht i need...pics are now unavailable...could fmc400 perhaps repost w pics?
  #34
Old 01-12-2011, 08:01 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
No problem. I've been working with one of the moderators (Blown331) who has been kind enough to help me update the photos. He has let me know that they should be updated fairly soon.
  #35
Old 01-12-2011, 08:25 PM
supercabfreak's Avatar
supercabfreak supercabfreak is offline
supercabfreak is starting off with a positive reputation.
did ford ever use any other type of choke stove than the one in the right side exhaust manifold? such as the gm one in the intake manifold?
  #36
Old 01-14-2011, 12:08 PM
Iowa Guy Iowa Guy is offline
Iowa Guy is starting off with a positive reputation.
This post is great and I'm anxious to see the photos. I just replaced the carb on my daughter's '76 F250 and I was left scratching my head on how the choke actually worked (I'm a bowtie guy so this blue oval stuff is greek to me but I'm learning thanks to you guys!). The 360 in her truck has both the heater hose bracket on the choke and the small heat tube (I don't know yet if it should go to the intake or the exhaust since I just found this post while I'm at work and will need to look at her truck).
Back to the header issue, it seems like I should be able to wrap some metal tubing around the header clamping it with a hose clamp with one end going to the choke connection and the other end to the carb air horn (with piece of rubber hose making the connection) so the choke pulls filtered air.
Now I just need to find that thread about how to fine tune these Motorcraft 2 barrel carbs! I've played around with it and got it close but some directions from the experts would be very helpful! *EDIT* Found the thread for the carb manual!
Last edited by Iowa Guy; 01-14-2011 at 12:27 PM. Reason: Found the thread regarding carb manual...
  #37
Old 05-24-2011, 11:01 AM
nlareau's Avatar
nlareau nlareau is offline
nlareau is starting off with a positive reputation.
awesome post
I looked for two days on the net trying to figure this out. Great post. Thanks a Lot!
  #38
Old 06-17-2011, 10:42 AM
troxedw troxedw is offline
troxedw is starting off with a positive reputation.
Should the vacuum generated in this hot air system be enough to cause an idle problem? With this hooked up on my truck it idles very rough and the truck doesn't run well. If I plug it the idle smooths out and the truck runs much better. I have a 75 F150, 360 2bbl, 4 speed.
Thanks
  #39
Old 06-17-2011, 06:53 PM
fmc400's Avatar
MSEE
Any vacuum leak can cause issues, especially if the engine's vacuum level is low enough. On a completely healthy engine maybe not, but if there are other conditions that could potentially lead to rough idle issues, then one more vacuum leak can be enough to cause a noticeable drop in performance.
What specifically must you plug to smooth out the idle?
  #40
Old 06-18-2011, 06:27 PM
Originally I had to plug the clean air line for the choke to make it run. I have since gone through all the vacuum lines and replaced them. I no longer have a problem with the choke circuit. The engine is original with 94k miles. All vacuum line were disconnected except for the distributor and power brakes. The EGR was hooked up but incorrectly. I re-ran the vacuum lines to the EGR going through the PVS valve but it developed a pretty good miss running down the road so I disconnected it for now. I got this truck from my father in law after he died. He had a friend that said he was a "mechanic" who worked on his truck. From what i've seen I don't think he knew much. When I got the truck he had manifold vacuum running to the EGR. Thanks again for the great write up on how the choke works.
  #41
Old 05-13-2013, 03:43 PM
weavec2004 weavec2004 is offline
weavec2004 is starting off with a positive reputation.
Quote:
I really need to see those photos. Any way to re-post them?
  #42
Old 05-13-2013, 06:33 PM
fmc400's Avatar
MSEE
They are on the first page. I updated them a long, long time ago.
  #43
Old 05-13-2013, 10:17 PM
I see them now. From my phone. Thanks!
  #44
Old 05-13-2013, 11:25 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Originally Posted by Dr. Dirt View Post
this should be a sticky...
... Added as a link in the the Tech Thread sticky.
  #45
Old 05-18-2013, 02:45 AM
rockittsled's Avatar
rockittsled rockittsled is offline
rockittsled is gaining momentum as a positive member of FTE.
I knew about the 7 volts, but did not realize it is 3-phase. guess that wouldn't work on a electric choke conversion, use the 12v instead
Choke Theory Question frank washington 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 56 12-17-2015 09:05 PM
Electric fuel pump conversion (pics) fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 31 07-11-2015 08:36 AM
FAQ - Choke questions answered ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 03-30-2011 08:20 PM
FAQ - Motorcraft 21xx 2V Carburetor ctubutis '80-'86 FAQs (Frequently Asked Questions) 0 01-30-2011 08:12 PM
Carburetor "Hot Air" Choke Hookup to 1985 F150 LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-18-2009 04:58 PM
Tags
1979, 360, 76, air, askcom, carburators, choke, custom, electric, engine, f100, f250, ford, heater, hot, motorcraft, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
