rear end clunking, '03 6.0 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-28-2008, 10:54 PM
jrock04 jrock04 is offline
jrock04 is starting off with a positive reputation.
Cool rear end clunking, '03 6.0
i drive a '03 6.o F250 and sometimes when i hit the brakes hard backing or forward i get a loud clunk in the rear. another thing i am curious about is this clunk i get in the front left over bumps, small or large. anybody have an answer or fix? i bought the truck a few thousand ago and it just slowly started this.
Old 12-28-2008, 11:22 PM
wheres the love?
Old 12-29-2008, 12:00 AM
Steve_250's Avatar
Steve_250 Steve_250 is offline
Steve_250 is gaining momentum as a positive member of FTE.Steve_250 is gaining momentum as a positive member of FTE.
My '03 and lots of others have needed the sway bar bushings replaced. Bad bushings causes the rattles under there over the bumps. Do a search for sway bar in the super duty section and you will find lots of answers.
As for the clunk in the rear, could be an indication that the rear spline needs to be greased, another common problem with the SDs.
Rear clunking sound mrad Excursion - King of SUVs 20 06-13-2013 04:32 PM
Clunk clunk noise flyer7.3 1999 to 2016 Super Duty 3 05-17-2011 02:22 PM
Clunk Clunk in front end stops when brake applied TrevorP 1987 - 1996 F150 & Larger F-Series Trucks 14 01-26-2008 01:23 PM
5R55 in 03 explorer clunking, slipping CTford Clutch, Transmission, Differential, Axle & Transfer Case 10 02-03-2006 03:48 PM
drivetrain clunk Michael60 Excursion - King of SUVs 3 06-05-2003 08:42 PM
Tags
250, clunking, duty, end, ford, rear, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
