WVO pumping
WVO pumping
What are you guys using to pickup WVO with. i found a guy who is selling a gas powered water pump real cheap. he said he used it to drain a pond. figure it should transfer oil pretty good. i have made a homemade filter with pvc pipe and window screen warpped around it to keep out any solids.
Trust me, if I had a role in it...it would only get below 60F for two weeks each year...and that would be Christmas to New Years for a snowy Christmas; I'd mandate 25-28F for the white stuff to stick around. The rest of the year it couldn't get below 60F or over 90F. I assumed the original poster was asking about pump WVO at the collection point...some where electrical heaters may not have a long enough cord to reach the 120VAC outlet; thus the use of a 12VDC pump.
How cold can it get before you start having issues pumping/vacuuming oil? Seems like there was a discussion in another thread (or a VO yahoogroup) that pumps like that are fine as long as the VO is in a liquid form, but once it gets cool that's when the 12V pumps don't have enough "guts" to move the oil.
i have the tuthil pump already. doesn't do the job very well. it was about 55 when i was pumping with it last. it lasted about 45 sec before blowing the fuse. had to put a bigger fuse. held my hand on the wire and pumped till it got hot(30sec). then let it cool down and did it again. took me about an hour to pump 100 gal, boy was that fun. i want something that will move the oil. i have been lucky till now and my fryer always put it back in the 5gal containers. lost my main guy but my new source and get me 400 gal just between the monthes of nov and dec. should i have any problems using a gas water pump?
Firemedic is right, build a super sucker. I cut a 1" hole in a horizontal 120 gallon propane tank to pressure out the oil after picking it up and used the 1 1/4" hole in the top to suck it in (so I don't have to lift the oil that is coming into the tank. I ordered a 12 volt air compressor from JC Whitney (Superflow Heavy-duty Air Compressor : JC Whitney: Auto Parts & Accessories), moved the outlet hose to the inlet port and use it for vacum. My compressor has pumped hundreds of gallons of oil without a problem.
I tried the Tuthill pump and it lasted for about 100 gallons. I sent it back for repair and haven't heard from them since then. In my view it is not suitable for the WVO.
Super sucker! recycled compressor w/ 80 gallon tank. I modified the compressor to do both vacuum & air pressure. It is driven by a 14hp gas engine. Takes ~1 minute to build ~30" of vacuum.
I have 20ft of 2" plastic hose attached. It really sucks!
However, because of the current WVO supply issues, I have not used it in a while.
sirnobody
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-20-2011 11:04 PM
dzzavid
03-06-2008 08:04 AM
78bigunns
01-04-2007 09:11 PM
ms1780
11-04-2006 09:50 PM
empiretc
06-14-2006 02:56 PM
