Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-28-2008, 08:55 PM
TxFordGuy TxFordGuy is offline
TxFordGuy is starting off with a positive reputation.
WVO pumping
What are you guys using to pickup WVO with. i found a guy who is selling a gas powered water pump real cheap. he said he used it to drain a pond. figure it should transfer oil pretty good. i have made a homemade filter with pvc pipe and window screen warpped around it to keep out any solids.
__________________
2002 F-250 Lariat 4x4 CC, 4" Magnaflow SS Exhaust, Wix 6637, Petes Cover, DP-Tuner
  #2 (permalink)
Old 12-28-2008, 10:34 PM
Rushmore X Rushmore X is offline
Rushmore X is starting off with a positive reputation.
So far we are doing things the old fashioned way with a hand pump, but have the plans and material to build a "super-sucker". Just need the time to build it...
__________________
2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, AFE stage 1 w/proguard, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, more to follow! Gone BIO!!!
  #3 (permalink)
Old 12-29-2008, 02:18 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE. orng1 has a good reputation on FTE.
I've been using this one and it's worked pretty good so far, I added a filter in line to it just to be sure. Makes straining obsolete, has a screen on the pick up too though.
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #4 (permalink)
Old 12-29-2008, 12:58 PM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
Super sucker...a 120 gallon propane tank drawn down to 28" of vacuum. I fill it up in under 15 minutes.
PM me your email address if you want pics
__________________
1999 F-350 with Tymar type air filter, Dahl 100 fuel filter, HP oil X-over, Zoo Dad, Bypass coolant filter.
1981 Mercedes 300 SD with Goldenrod water block fuel filter and injection line heaters.
Both fueled on single tank WVO blend.
  #5 (permalink)
Old 12-29-2008, 01:05 PM
orng1's Avatar
Quote:
Did I forget to put the link?
Tuthill Diesel Fuel Transfer Pump with Hoses — 12 Volt, 10 GPM, Model# FR1614 | DC Powered Pumps | Northern Tool + Equipment
__________________
  #6 (permalink)
Old 12-30-2008, 07:25 AM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is starting off with a positive reputation.
How cold can it get before you start having issues pumping/vacuuming oil? Seems like there was a discussion in another thread (or a VO yahoogroup) that pumps like that are fine as long as the VO is in a liquid form, but once it gets cool that's when the 12V pumps don't have enough "guts" to move the oil.
__________________
1972 Ranchero GT 351C (Engine code "Q")
2001 Explorer XLT 2WD
2004 F250 PSD CC Lariat 2WD "Pavement Princess" (bone stock...for now)
  #7 (permalink)
Old 12-30-2008, 07:36 AM
orng1's Avatar
Don't let it get that cold, warm up a part and let the pump recirculate the oil in the container. The pump itself gets pretty hot so I imagine that would be enough to get it moving. They also sell the heating straps if you look around.
__________________
  #8 (permalink)
Old 12-30-2008, 08:37 AM
zhilton's Avatar
2004 Ford F-250
My Garage
Trust me, if I had a role in it...it would only get below 60F for two weeks each year...and that would be Christmas to New Years for a snowy Christmas; I'd mandate 25-28F for the white stuff to stick around. The rest of the year it couldn't get below 60F or over 90F. I assumed the original poster was asking about pump WVO at the collection point...some where electrical heaters may not have a long enough cord to reach the 120VAC outlet; thus the use of a 12VDC pump.
__________________
  #9 (permalink)
Old 12-30-2008, 10:28 AM
Quote:
Seems for us anyway that once it starts getting into the teens, the WVO becomes slushy and takes alot more effort to pump. At zero or below forget it, is almost frozen solid (at least the water is easy to remove, it forms a layer of ice on the top) From reading this and other forums it seems that we might have hydrogenated oil...
__________________
  #10 (permalink)
Old 12-30-2008, 10:34 AM
zhilton's Avatar
2004 Ford F-250
My Garage
__________________
  #11 (permalink)
Old 12-30-2008, 01:49 PM
Jack_99V10 Jack_99V10 is offline
Jack_99V10 is starting off with a positive reputation.
DFA is selling a nice pump now.
__________________
2000 F350 CC LB - DP Tuned - 9" lift - 40" Tires - Vegistrokin since 08/23/08
http://i2.photobucket.com/albums/y9/...ig_500x100.jpg
  #12 (permalink)
Old 12-30-2008, 08:17 PM
i have the tuthil pump already. doesn't do the job very well. it was about 55 when i was pumping with it last. it lasted about 45 sec before blowing the fuse. had to put a bigger fuse. held my hand on the wire and pumped till it got hot(30sec). then let it cool down and did it again. took me about an hour to pump 100 gal, boy was that fun. i want something that will move the oil. i have been lucky till now and my fryer always put it back in the 5gal containers. lost my main guy but my new source and get me 400 gal just between the monthes of nov and dec. should i have any problems using a gas water pump?
__________________
  #13 (permalink)
Old 01-03-2009, 10:44 AM
Knotwild Knotwild is offline
Knotwild is starting off with a positive reputation.
Firemedic is right, build a super sucker. I cut a 1" hole in a horizontal 120 gallon propane tank to pressure out the oil after picking it up and used the 1 1/4" hole in the top to suck it in (so I don't have to lift the oil that is coming into the tank. I ordered a 12 volt air compressor from JC Whitney (Superflow Heavy-duty Air Compressor : JC Whitney: Auto Parts & Accessories), moved the outlet hose to the inlet port and use it for vacum. My compressor has pumped hundreds of gallons of oil without a problem.
I tried the Tuthill pump and it lasted for about 100 gallons. I sent it back for repair and haven't heard from them since then. In my view it is not suitable for the WVO.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP turbo back exhaust, 6637 intake mod, Dieselsite 203 thermostat.
  #14 (permalink)
Old 01-07-2009, 10:20 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a good reputation on FTE. empiretc has a good reputation on FTE.
Super sucker! recycled compressor w/ 80 gallon tank. I modified the compressor to do both vacuum & air pressure. It is driven by a 14hp gas engine. Takes ~1 minute to build ~30" of vacuum.
I have 20ft of 2" plastic hose attached. It really sucks!
However, because of the current WVO supply issues, I have not used it in a while.
__________________
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 200k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
