Taller Gears on a 4x4
Quick question on gears.
I'm used to cars, so bear with me on a silly question... But, it stands to reason that if you put taller gears in the rear, you will need to do the same for the front as well for the 4 wheel drive to work properly, correct? With 35's, I have a feeling some gearing would go a long way to give ol' Franklin some get up and go.
What are you guys running? And whats an average price to have the job taken care of?
Thanks,
B.J.
Thanks,
B.J.
Front and rear sets are rarely the same identical ratio, but they have to be within 1% of each other. We could be confusing terms, but I always understood taller gearing to be higher gearing, or lower numerical ratios and that's not the direction you need to go. I've run various size tires through the years and with true 35" tires, 4.56 would be your best bet. A tire with an unloaded diameter of 35", is going to yeild a smaller loaded radius than 16.5". If you don't have overdrive, you might want to opt for 4.10. 4.33's would be the best fit, but not knowing the axles in question, it may not be available. If you don't intend to do the work yourself, you're probably looking at $800 per axle, give or take. Certain gear sets require a different carrier, like the Dana 44 as well as other axles, which increases the cost. It's a good time to upgrade to better limited slip differentials.
skidoorulz
02-10-2015 05:02 PM
460 FORD MAN
05-12-2013 01:55 PM
64F260
35
01-26-2010 01:51 PM
