Torque specs on 390 Rockers? - Ford Truck Enthusiasts Forums
Old 12-28-2008, 05:48 PM
78ford351m 78ford351m is offline
78ford351m is new and has a neutral reputation at this point.
Anyone know what these are? I had to pull the push rods and rocker arm assembly off today and want to know what these are for when I put it back together. Torque specs for the intake would help too. Thanks in advance.
Jason
Old 12-28-2008, 06:26 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Ford sez:
Valve rocker shaft support to cylinder head = 40-45 ft/lbs
Valve cover = 4-7 ft/lbs (half inch nut driver?;)
Intake manifold to cylinder head =40-45 ft/lbs
Oops, but already got it typed out ;)
Cylinder head bolts step 1= 70 ft/lbs
Cylinder head bolts step 2= 80 ft/lbs
Cylinder head bolts step 3= 90 ft/lbs
Old 12-28-2008, 06:30 PM
Quote:
Originally Posted by Alvin in AZ View Post
Ford sez:
Thanks man. I found this walkthrough on this site and have been following it. POTHSPROJECTS • View topic - How to: Replace Intake Gasket on a 390FE and Big Blocks
Performer Manifold - Need torque specs pls! Jason Neuman 1967 - 1972 F-100 & Larger F-Series Trucks 9 09-22-2014 09:37 PM
chevy rockers??? JoeDaf Ford Inline Six, 200, 250, 4.9L / 300 10 05-06-2014 04:24 PM
Torque specs johnsjsj 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-07-2013 11:05 PM
torque specs for rocker arms on 3.0L????? 97 bonestock Ranger & B-Series 2 11-17-2009 11:58 AM
Rocker Arm/Intake Torque Spec Blurry94 3.8 & 4.2L V6 4 04-01-2004 07:14 AM
Tags
1973, 390, assembly, cover, cylinder, f250, fe, ford, head, pattern, rocker, shaft, specs, torque, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
