another step along the way - Ford Truck Enthusiasts Forums
Old 12-28-2008, 10:42 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
well, I finally got the pulley mess sorted out (gosh these serpentine belts require a lot of tension) and we took her for a 2 mile around the block test drive.. nice.. the power brakes work good (need to adjust the prop valve) and the air bag rear was ok..
need to get the volare front end adjusted and aligned now.
the roads at the new house were tarred and rock covered this last spring, and so there is a bunch of loose stone still (ugh!)..
now to get back working on the bed wood retainers, so I can start working on the wood finish itself, and the windows & door latch pulls..
still haven't found any gauges to replace the poorly made Hanelines.
Sam
Old 12-28-2008, 11:45 AM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Quote:
Sam
Would you like to trade for Havi's (and mine) 6 feet of snow? Huh? Huh? (Please)
Old 12-28-2008, 11:49 AM
sdetweil's Avatar
Quote:
not really, but then I wouldn't have even THOUGHT about taking it for a spin around the block..
As a displaced northerner (Michigan) I do miss the snow (occasionally)
Sam
reverse tilt hood adjustment sdetweil 1948 - 1956 F1, F100 & Larger F-Series Trucks 60 09-04-2016 02:43 PM
carburerator issues Jacksoncummins79 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-25-2015 05:18 PM
Good Sam Membership kehinnc Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 6 07-23-2012 11:27 AM
tow mirror fold doesn't sdetweil 1999 to 2016 Super Duty 12 11-17-2009 09:24 AM
SAVAGE SAM DO YOU HAVE dPPi EXHAUST mrw1125 6.0L Power Stroke Diesel 0 01-26-2004 10:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
