1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Has anyone replaced engine mounts on 2003?
Old 12-05-2018, 07:21 AM
broncoholic's Avatar
broncoholic
broncoholic is offline
Took it in for an oil change and alignment, and they told me the hydraulic engine mounts are starting to leak. I did a search on the forum and didn't find anyone else having leaks or replacing the mounts. I'm wondering if I'm going to need an engine hoist or if I'll be able to jack against the block and replace 1 side away a time.
Old 12-05-2018, 09:39 AM
Hamfisted's Avatar
Hamfisted
Hamfisted is offline
Is it a 2WD model ? You can lift from underneath with a 4x4 block of wood and jack (bottle or floor jack...). Pull the starter, oil dipstick tube, and front sway bar off. Unbolt the rear tranny mount so it has freedom to move too. If it's a 4x4 model I'd let it go till the motor is dragging on the front axle 'cause it's a severe pain in the tail.
Old 12-05-2018, 11:19 AM
broncoholic
4x4, of course. Nothing I get into is easy lol
Mearntain
04-10-2019 09:48 AM
945SPD
13
02-13-2019 05:33 PM
85AustinTucker
07-26-2015 02:20 PM
KIKKUP
16
03-29-2013 09:57 AM
curt.farmer712
12-03-2010 09:45 PM
Quick Reply: Has anyone replaced engine mounts on 2003?
