Prepping early V-8 for rebuild - Ford Truck Enthusiasts Forums
Old 12-28-2008, 04:22 AM
bergieb bergieb is offline
bergieb is starting off with a positive reputation.
My question deals with the necessity/advisibility of a final chemical (Redi-strip?) or thermal (bake and shake?) stripping of the flathead block after the hot tanking, Magnafluxing, and machining. I'm in the Des Moines, IA area and am not aware of any stripping process available other than bead blasting. I am dubious of the effectiveness of media blasting to remove rust and scale from the internal areas of the water jacket and if all the media itself can be gotten back out of the recesses of the jacket and threads. Any advice would be appreciated.
Old 12-28-2008, 10:59 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Many folks have found that a sharpened steel rod is useful for chipping away at the stuff while the block is bare and on a stand. Hi-pressure washing may help break it loose. I wouldn't try media blasting on the internal passages, I doubt you can really get to most of the areas anyway, and it is just too hard to get all of the media back out of there. Acid washes don't seem as effective as the chipping. The stuff is like cement!
While you have it bare, it's a good time to consider a "Canadian" full-flow oil filter conversion, since the drilling for it creates chips in the oil passages.
Old 12-28-2008, 11:58 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
You might want to try spraying white vinegar in the water passeges, spray a couple times, let it work over night and spray it again. It might help loosen the calcuim build up a bit. Also, you can clean the outside with diesel fuel. Spray it on and let it soak a bit too.
Julie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
