The only thing I would do differently is rectangle tubing instead of the angle iron welded together. If you have to pull sideways for some reason, your frame brackets are going to want to turn. It will either twist and
break the welds at the bumper itself. Or worst case, it will rip the bolts out of the frame horns. Square tubing into the frame will transfer some of the load into the frame rails themselves, making the mounting stronger.
I've repaired a few frames because of this.
I would have usde square tubing for the outer bumper as well to give you more surface area to weld to
Just my .02 worth
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
