Mechanical stripping, as seen on tv :) - Ford Truck Enthusiasts Forums
Old 12-27-2008, 07:14 PM
Gary E's Avatar
Gary E Gary E is offline
Gary E is gaining momentum as a positive member of FTE.
So I was watching hot rod tv the other day, and I think they were doing a 74ish charger for Kenny Wayne Shepard or something like that and the started stripping the paint on the fender, and it was super fast, looked like a DA sander but it looked like they would have the fender done in about 5 minutes, what were they using? Granted my DA sander is a budget IR one but no way it would knock the paint off that fast.
Old 12-27-2008, 07:32 PM
LEckart's Avatar
LEckart LEckart is offline
LEckart is starting off with a positive reputation.
Most likely they were using a paint stripping disc by 3M. They are a very coarse/swiss cheese/looking disc, black in color. Kind of hard to describe. That's my guess anyway.
Old 12-27-2008, 08:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
There's no trick to getting paint off fast, just doing it without damaging or warping the metal. Norton makes a red 7" disc that looks like it has gravel bonded on it, it is mostly for prepping steel shapes for painting. It'll strip epoxy like no tomorrow.
Old 12-28-2008, 02:26 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Yes that's true getting old paint off isn't a big problem. The challenge is getting it off without digging troughs in the layers of paint underneath. Remember that eventually you are going to have to hand sand that fender smooth and feather it out if you expect to have a decent paint job.
An electric orbital sander with 80 grip paper will take a fender down in 30 minutes. Or if you have a compressor with a 9cfm flow rate you can orbit sand it off.
One of the reasons you have to be careful is because you don't know what's under that paint and if there's some filler or bondo you don't want to gouge into it.
Be patient with body work- especially sanding.
Julie!
Old 12-28-2008, 06:27 AM
Brian_B's Avatar
Brian_B Brian_B is offline
Brian_B is gaining momentum as a positive member of FTE.
Yes...I agree you need to be careful.
Mine has spray paint, rustoleum, and who knows what on top. It is really soft and clogs the sandpaper fast . I use a chemical stripper to get the junk off the top (scrapes right off with a putty knife). Then I switch to my electric rotary sander ($25 at HF on sale). I have an 8" ferro backing pad and 8" indasa 80 grit disks. You can strip most of a panel fairly quickly, but again..be careful.
I them switch to a little (air) angle die grinder. I use 2" roloc 50 grit disks on it. Again being careful.
There will always be spots that need to be hand sanded.
I am going to bare metal.
I will not leave filler or anything on the surface. The particular epoxy primer I am using requires an 80 grit surface to stick. A couple of coats and it is pretty smooth.
If you go the route of sandpaper...do not...I repeat...do not buy the cheap stuff. It will work you to death with very little results. Believe me..I tried it at first.
Now..that works on a panel at at time. I intend to media blast the bigger stuff when I get to it.
Unfortunately (and very fortunately!!!) I received a kidney transplant last spring. I didn't much at all done on mine this past summer. I will continue when the weather warms up. I don't have a place to get it indoors to work on it.
Old 12-28-2008, 09:17 AM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I've used a product from 3M called a ROLOC BRISTLE DISC, fits on a 4 1/2 grinder, takes it to bare metal in seconds. But like any friction pad you have to keep it moving so you don't build up heat. I paid $32 for it and it does last for a fairly long time. I found out about them watching Trucks TV.
Old 12-28-2008, 11:25 AM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
I usually try to distinquish which panel is original paint/painted multiple times or bondo and go from there.
If I think the panel is nice--I will strip it with a roloc--or a 24 grit disc.
If panel is 50 yrs of old body-work--you had better decide if you are going to dig out all the old stuff--or sand it and refinish it.
On a 53 that I have--it is at least 7 paint jobs old, and I sanded it with da and primed it.
In spring--I will decide to strip roof/hood/and MOST LIKELY just sand and refinish the rest. You do not have to make a show finish on every panel--if it is a driver--make it presentable and drive it.
Bondo and lead are in alot of old trucks and if you want ALOT of work--start digging it all out....haha
You may be buying a new panel when you see under all that paint and filler!!
When you grind a panel--try to machine it and make it look machined--instead of gouged up!! I have taught alot of laborers this technique--and when it is gouged up--you have alot more to do!! Bill
Dual action Sanders Lucas Orsborn Paint & Bodywork 7 02-08-2013 06:28 AM
What size air compressor minnesotafisherman Paint & Bodywork 7 04-30-2012 12:42 AM
Paint, body question. way2fast1 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 01-11-2012 02:02 PM
DA Sander Advice Runningmanf250 Garage & Workshop 7 08-20-2007 07:11 PM
DA Sander CFM??? weadjust Garage & Workshop 4 07-04-2005 07:08 AM
Tags
ford, trucks, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
