Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 12-29-2008, 11:15 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation
Well, I did some more digging into the FAA's bulletin and guess what? Its about automobile gasoline use in planes. In 1982 the FAA added the Supplemental Type Certificate (STC) which allows certain planes (such as many Cessna's) to use automobile gasoline, which costs less.
The bulletin was put in place to warn STC pilots not to use automobile gasoline in these planes if it contains ethanol and automobile gasolines containing MTBE or ETBE are acceptable.
Quote:
Neither the EAA STCs, nor Petersen Aviation STCs, allow the use of automobile gasoline containing alcohol ethanol or methanol). Automobile gasolines containing MTBE or ETBE are acceptable.
Automobile gasoline containing alcohol is not allowed to be used in aircraft for the following reasons:
• The addition of alcohol to automobile gasoline adversely affects the volatility of the fuel, which could cause vapor lock.
• Alcohol present in automobile gasoline is corrosive and not compatible with the rubber seals and other materials used in aircraft, which could lead to fuel system deterioration and malfunction.
• Alcohol present in automobile gasoline is subject to phase separation, which happens when the fuel is cooled as a result of the aircraft’s climbing to higher altitude. When the alcohol separates from the gasoline, it may carry water that has been held in solution and that cannot be handled by the sediment bowl. 2
• Alcohol present in automobile gasoline reduces the energy content of the fuel. Methanol has approximately 55 percent of the energy content of gasoline, and ethanol has approximately 73 percent of the energy content of automobile gasoline. The greater the amount of alcohol in the automobile gasoline, the greater the reduction in the aircraft’s range.
Recommendation
We recommend that you do the following about operating airplanes using automobile gasolines:
1. Use automobile gasoline that conforms to the specifications listed in the airplane flight manual or automobile gasoline STC flight manual supplement:
a. Verify the fuel has the proper octane rating
b. Verify the fuel has the allowable oxygenates: i. Automobile gasolines containing MTBE or ETBE are acceptable. ii. Automobile gasolines containing alcohol (methanol or ethanol) are not acceptable, unless specifically approved by the TC or STC.
2. If you are unsure about the presence of alcohol in your automobile gasoline, the following test can be performed:
a. Using a glass or chemicalresistant plastic (such as TPX) container, mark ten equally spaced volumes. A graduated cylinder is ideal; however, a non-tapered glass jar, such as a large (quart) olive bottle, will work.
b. Add one part water (approximately 100 ml) into the container, fill to the first mark, and then add nine parts (approximately 900 ml) of automobile gasoline, fill to the top mark. Shake thoroughly, let stand for 10 minutes or until automobile gasoline is again bright and clear. Record the apparent level of the line between the automobile gasoline and water.
3. If alcohol is present in the automobile gasoline, the water will absorb it, and the amount of water will appear to increase, indicating the automobile gasoline should not be used in the aircraft.
However, if the water level remains the same, no alcohol is present in the automobile gasoline, and it can be used in the aircraft.
4. If you cannot obtain automobile gasoline that conforms to the specifications listed in the airplane flight manual or automobile gasoline STC flight manual supplement, use aviation gasoline conforming to ASTM specification D 910.
__________________
-Ken
If you need to get in touch with me email me at ftsservice at gmail dot com or via AOL IM: motorhavenken.
The best is yet to come....
  #32 (permalink)
Old 12-31-2008, 01:44 PM
beef producer beef producer is offline
beef producer is starting off with a positive reputation.
Tennessee can fine you up to $10,000 for running dyed fuel in any over the road vehicle and they do spot check trucks.
  #33 (permalink)
Old 01-01-2009, 09:32 AM
pmasley's Avatar
pmasley pmasley is offline
I Be The Instigator
pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold pmasley is a splendid one to behold
They can spot check you in WV too. I have already been through two of them. When the fuel problem happened after Katrina, the restriction was lifted in this state for running dyed fuel. I did have to use it for a while.
Once the dyed fuel is put in your vehicle, it is there permantly. You cannot get it out unless you completely tear down the system and flush it, and replace certain componets. Well, now several years later, when I change my fuel filter, it still comes up with red dye in it. Sorry DOT, I am not spending over grand just to tear down the system and flush the dye. That is what I told the last inspector. It sorta pissed him off, but there is nothing he could do. His sample showed clear, but the filter check showed the dye. It seems that the dye melts into the plastic lines and is slowly release until the plastic lines are replaced.
Nope, NADA, Ain't gonna do it!
__________________
Paul
West Virginia Chapter
2001 F-250 7.3 Powerstroke Super Duty XLT Extended Cab 4X4 6 Speed 3:73
Goodyear Wrangler 305/70R16 ATS Tires
Banks Intercooler, tubes and 1999 Turbo Wheel
Steel HPX and CCV Mod
Bully Dog 4" Exhaust and AIS II Air Filter
FTE TEAM MEMBER of 53449
Member "Boy you ain't right club#7"
  #34 (permalink)
Old 01-02-2009, 07:14 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
One must remember that the farm lobbyists are not the same as your family farmer...
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #35 (permalink)
Old 01-04-2009, 07:21 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of
Quote:
Originally Posted by FTE Ken View Post
Some bobcats
I checked
gehl's site,
case's site
new holland's site
John Deere's site
bobcat's site
NH's smallest skidsteer is gas with a diesel option.
I think new gas equiptment in this size equiptment and larger is dieing off.
__________________
06 F250 CC v10 4x4 Lariat
RIP BIG GREEN owned her from 08.17.04 - 05.10.08
  #36 (permalink)
Old 03-02-2009, 02:54 AM
icrman icrman is offline
icrman is starting off with a positive reputation.
Yeah funny stuff. The reason for them adding alcohol is to reduce the miles per gallon, and force ya to buy more gas. Its all just that simple. Just talk to anyone that uses it in a race car, you have to enrichen the mixture way more than what it is for gasoline to get the power.
And then theres the affinity it has for water, lots of stories on the news about big repair bills from that.
__________________
1996 F-250, XLT 460 E4OD, Long box, Supercab 4X4, 4.10 Axle Ratio, Camper and tow package.
Self install of: Clifford alarm, B&W Flipover gooseneck hitch, Ride Rite airbags, and compressor system, Prodigy Brake controller.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
