Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-27-2008, 03:15 PM
v8xploder's Avatar
v8xploder v8xploder is offline
v8xploder is starting off with a positive reputation.
351 lower manifold to 5.0 upper.. ?? Help!
At one time last year I had found at one of the bronco parts sites a 351 lower manifold that will bolt to a 5.0 upper manifold. I have the entire FI set up off of an 89 5.0 H.O Mustang which I want to put on my 69 bronco's 351W. Anyone remember the site or know where to find one ive been looking all day!
__________________
Cody
69 Bronco, 351W, Edelbrock performer, Holley 670 T/A 35'S 5.5'' Wildhorses lift, Locker rear, F-100 power steering and a slight rear main leak
92 Bronco Eddie Bauer, 351w, 31x10.50 No rust!!!
  #2 (permalink)
Old 12-27-2008, 11:28 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
I remember seeing an adapter to mate the HO upper to the 5.8 truck lower, is that what you mean? I assume you're doing this for hood clearance? If that's the case then this should gain some, though its hard to say how much after the adapter is added. If you're looking for more HP I don't think you'll find it, the HO intake doesn't flow as much as the 5.8 truck intake. In that case what you want is the Eddy Performer(car version), or for about 1/2 the $$ the Professional Products Typhoon.. a Performer copy.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 12-28-2008, 02:00 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
The main purpose is to bolt the 5.0's upper to the cheap 351 truck lower to fit under the EB hood.
B.C. Broncos - EFI / Fuel Injection Fuel Systems
about 1/2 way down the page.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #4 (permalink)
Old 12-28-2008, 08:21 PM
v8xploder's Avatar
I have 100% complete Speed density system. I decided to go with the manifold adapter from BC, once I find a lower manifold for my 351. Which intake gaskets would I use then?? 79 351W? Or whatever year the lower manifold is from.... or are they the same???
__________________
Cody
  #5 (permalink)
Old 01-02-2009, 12:30 AM
v8xploder's Avatar
Conanski, What do you think about your typhoon? Complaints? According to an article in fordmuscle they had to do a lot of gasket matching. Which isnt a big deal.... I dont know if it would be a good Idea for me to get a nice intake as I will be running a speed density set up for a while.....
__________________
Cody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
