Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-27-2008, 03:45 AM
Tarasque174 Tarasque174 is offline
Tarasque174 is starting off with a positive reputation.
Super6 4.2L Stage 3 power pack
Hey guys I'm a noob to these forums, but I have learned a lot from you guys. I was wondering has anyone tried the Super6 stage 3 power pack for the 4.2 V6? The kits seems nice and adds a lot of usefull power to the trusty V6. For the price and what you get, plus an extra 90 horses....
And also at TMA tubor (STREET KIT), has anybody tried this turbo kit he has fabed up for the 3.8 mustang. I looks like it will fit and the 4.2 again is just the big brother to the 3.8.
Let me know what you guys think about these two items.
Terry
  #2 (permalink)
Old 12-30-2008, 06:08 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a very good reputation on FTE. BrianA has a very good reputation on FTE. BrianA has a very good reputation on FTE. BrianA has a very good reputation on FTE.
Terry,
Nice to have you here!
I don't recall ever seeing those mentioned. Maybe somebody has posted about them and I just missed it.
The turbo add-on seems pretty pricey - I do not remember anyone here going that route.
Either way, glad to have you join us. Hope you stick around.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #3 (permalink)
Old 12-31-2008, 09:14 PM
Thanks for the reply!
Thanks BrianA, I just saw that site for the turbo kit for the 3.8V6 Mustang, and the price is way better then other kits I have seen so far. I did a search before I did the thread, and did not find anything on either topic. I have been looking for the best way to add some extra power to my 2000 XLT Ext Cab 4.2 (5 speed), and the Super 6 seems like the best route so for, I mean for an extra 90HP the price isn't to bad.
  #4 (permalink)
Old 01-11-2009, 09:31 PM
Oggie's Avatar
Oggie Oggie is offline
Oggie is starting off with a positive reputation.
Talking
Hey Terry,
Kinda curious about this Super 6 you're talking about. Where can I find some more info on it? My motor has plenty of grunt to get moving. But, I would like a little more in the top end. I have to haul a 325 gal water tank and would like to have a little more juice when I need it.
Is this one of those plug and play deals like the diesels have? Boy would I like to shove that up my son's nose. Especially since I have to beat him to keep him out of my truck right now.
Take care and long live the 4.2.
  #5 (permalink)
Old 01-12-2009, 09:02 AM
BrianA's Avatar
Hey Oggie,
You might want to consider looking into a rear-end gear swap.
Do you have the 3.55 rear end?
I think you can get 4.11 gears installed. That might be just the ticket if you are needing more oomph to haul around a big water tank.
__________________
Brian A
  #6 (permalink)
Old 01-21-2009, 01:08 AM
Reply to Oggie
The link is Super Six Motorsports
They have some cool stuff for us the 4.2L V6 guys. The Stage 3 kit is for manual trucks and stage 2 is for autos. It comes with all the parts you'll need in the kit. Its no plug and play. At there site its under power packs on the left side. Here's what they say about the kit,
Super Six Motorsports Orders: 478-256-7766
We pioneered the PowerPak concept in the V6 community through extensive dyno testing. PowerPaks are our specialty; they are
more than just heads, intakes, and a cam --they are part of a comprehensive engine system where each component has been
designed and tested to work together. These parts are also available separately so you can build your own PowerPak as budget
allows. PowerPaks are offered in stages, see recommendations in the chart below. Superchargers and turbos are very popular
additions, but there’s no denying that they often cause harmful engine stress and catastrophic failure of the stock hypereutectic
pistons and stock powder metal rods. If your car is your daily driver, our PowerPaks may be just the solution you are looking for…
Extra power and no harmful engine stress!
99-up 3.8 V6 Mustang 97-up 4.2 V6 F-150 PowerPak
Stage 2: Ported upper intake, ported lower intake, Stage 2 cylinder heads with 1.86/1.45 stock valves, SSM custom regrind Delta cam : $1900* adds up to 70 horses, saves $!
Stage 2+: Ported upper intake, ported lower intake, Stage 2+ cylinder heads with 1.90/1.50 stainless steel valves, SSM custom ground CompCams billet cam included: $2500* adds up to 80 horses, saves $!
Stage 3: Ported upper intake, ported lower intake, Stage 3 SuperHeads with 1.94/1.56 stainless steel valves, SSM custom ground CompCams billet cam included: $2700* adds up to 90 horses, saves $!
* $200 refundable core
Options:
Installation kit: Gaskets, sealants, head bolts, t-stat, etc: $285, BBK 65mm
throttle body: $240, CompCams billet cam upgrade: $175, SSX sheetmetal upper
intake: $750
I think for the money and the power you get in return is worth it.
They also have an M-112 Adapter Intake Manifold. Adding an M-112 blower from the 03-04 Cobra can add 100 RWHP/RWTQ to your 99-04 3.8 Mustang or 96-up 4.2 F-150. Our adapter manifold makes this very simple. Heres all you need to source from an 03-04 Cobra: M-112; inlet plenum; throttle body, cable, and bracket; air induction, meter, filter, and #39 injectors. Add a bigger fuel pump and water/meth kit and a few small parts and have it tuned. Detailed installation instructions provided with each adapter. $900
  #7 (permalink)
Old 01-23-2009, 09:53 PM
Oggie's Avatar
Talking
Hey thanks for the info. I hadn't thought about a gear swap. I don'[t think I could slide that by the "financial adviser". I am going to look a little more into that power kit. They had some long stroke blocks that looked kinda interesting there too. Have to lwaith and see what I can talk she who rules my world in to. Thanks alot.
  #8 (permalink)
Old 01-24-2009, 10:50 PM
mustangman02232's Avatar
mustangman02232 mustangman02232 is offline
mustangman02232 is starting off with a positive reputation.
Quote:
Originally Posted by BrianA View Post
Terry,
ive posted it a few times, Delk performance also makes some good v6 stuff, my car is going to be getting a forged 4.3 short block (4.2 boared .030) with a stage 3 head package and 218/224 cam.
andy at TMA makes good turbo kits, but im personally going with an eaton M112 for my stang nothing beats the screaming 3 year old wine
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
