Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-26-2008, 09:29 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 is starting off with a positive reputation.
few questions about my 94 L
Just got it today and have a few questions
Cruise control isn't working for me. Is there a secret to it?
Can I use my 9mm Ford Racing plug wires off my 5.0 F150 on the Lightning? Also have an MSD dist cap and rotor on my 5.0, can that swap over to my Lightning?
It has a kenwood deck on it now and I want to put my Alpine deck from my 86 on it. Will I have to buy the wiring kit for it?
__________________
94 Lightning
Ford motorsports shorty headers.Borla catback
Alpine CDA-9883,(2)AudioQue HDC3 10" subs
,AudioQue 3500D amp,200 amp alt,0 gauge
,Kicker KS components. Optima battery
8000k HID headlights and foglights
86 F150
DJM 3/5 drop.To much to list!(Sold)
  #2 (permalink)
Old 01-04-2009, 09:20 PM
dicksshortwide66 dicksshortwide66 is offline
dicksshortwide66 is starting off with a positive reputation.
Welcome to the board!! the cruise may be disconnected,due to the fire hazard, Ford did a recall,you might want to check into that and the fuse box.does the horn work,if not it is probably the fuses.The Ford racing wires are gonna fit, but, the resistance is higher than the stockers.Try Taylors, do a search here, has alot more info on the best trucks, our gen1's.Alot of the newer stereo harnesses cover alot of years on the older stuff and you could get lucky or just use the one off the kenwood. again, Welcome
__________________
[SIGPIC]66 F100 shortwide,sundays, with some kind of fe,wheels off my son's
94 Lightning,my 4 year old's,69,000,351w,lumpy roller cam,stealth intake,C6 w/underdrive,3.50 9'',factory stuff put away.
99 Exploder sport,5 speed,cai,hot coil,opened spark plugs,lowered 2'' for fuel economy
  #3 (permalink)
Old 01-05-2009, 01:57 AM
86F150302's Avatar
I got my Alpine put in.
Yes the horn does work.
Im just going to buy new plugs,wires and dist cap.
__________________
94 Lightning
86 F150
  #4 (permalink)
Old 01-05-2009, 06:15 AM
Gen 1 driver Gen 1 driver is offline
Gen 1 driver is starting off with a positive reputation.
86
If you can't get the answer from Blurry 94 on this site you just didn't need to know.
Mike
  #5 (permalink)
Old 01-05-2009, 11:09 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE. Blurry94 has a very good reputation on FTE. Blurry94 has a very good reputation on FTE.
Your failed CC cab be one of two things; a faulty disable switch mounted on the master cylinder or a bad clock spring in the steering wheel. The disable switch on your 94 should be covered under the CC recall through Ford if that is the culprit.
I believe all of your ignition components will swap over as well as your Alpine head unit; I'm assuming it already has an adapter harness and you just need to splice the Alpine harness to it.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, ARP hardware, Canton main girdle, FMS Mass Air and tuned with SCT software.
  #6 (permalink)
Old 01-06-2009, 01:45 AM
86F150302's Avatar
Ok I went ahead and bought new plug wires and dist cap.
What are some quick mods I can do to get some more power? Custom intake? Ill change the exhaust up one day. Can I bump up the timing? I use 90 octane BP gas in it.
What plugs should I get and what should I gap them to? I have NGK V powers in my 86 and never had a problem.
__________________
94 Lightning
86 F150
  #7 (permalink)
Old 01-06-2009, 11:21 PM
Blurry94's Avatar
NGK plugs are good; just gap them to OEM specs. You can bump the base timing up a few degrees, that's about the best quick mod you can do. If you hear the engine knock under heavy throttle then just back it off a couple of degrees.
For the exaust and intake, I'd do a CAI when with a header/exhaust upgrade. The stock inlet tract doesn't leave much room for expansion and the stock exhaust system has 4 cats and two mufflers, so you have an idea as to how restrictive both systems are.
__________________
Matt C.
  #8 (permalink)
Old 01-07-2009, 02:13 AM
86F150302's Avatar
Ok thanks
It has shorty headers and Borla catback exhaust on it right now. Im wanting to go with LT headers, x pipe and Flowmaster 44s with gen 2 exit.
Underdrive pullies worth the money?
__________________
94 Lightning
86 F150
  #9 (permalink)
Old 01-07-2009, 04:25 PM
V8muscle V8muscle is offline
V8muscle is starting off with a positive reputation.
The cruise actuators are also known to fail. Probably due to their mounting location. They are a Lightning only part. BIG $$$$ compared to the regular F150 part. They were still available a year or so ago.
Bill
__________________
Ford Truck History
1976 F150 4x4 360 gone
1976 Bronco 302 gone
1978 F250 4x4 400M gone
1986 Bronco II 2.9L gone
1995 F150 Lightning 18K miles
2003 Excursion Eddie Bauer 6.0L
1956 F100 under construction
  #10 (permalink)
Old 01-07-2009, 10:54 PM
Blurry94's Avatar
I'd recommend a shift kit and traction bars before pulleys.
Long tube headers will make a difference. These pics are of the exhaust system I run on my GEN 1.
__________________
Matt C.
  #11 (permalink)
Old 01-12-2009, 03:22 PM
86F150302's Avatar
Looks sweeet
What headers and muffler is that? Could I fit an X pipe in there somewhere and have the gen 2 exit?
I have 2 flowmaster single chambers that I never used from my old truck that im wanting to use when I do my exhaust on my L. I live in FL so I dont need cats
__________________
94 Lightning
86 F150
  #12 (permalink)
Old 01-14-2009, 08:02 PM
lobo1117's Avatar
lobo1117 lobo1117 is offline
lobo1117 is starting off with a positive reputation.
Welcome.. not trying to rustle members from the board,
but the Lightning Owners site The National Lightning Owners Club provided tons
of help for my Bronco conversion.. you might want to look
at their site in addition to this one.. hope this doesn't offend anyone
  #13 (permalink)
Old 01-17-2009, 03:20 AM
86F150302's Avatar
im on there too. Name is also 86f150302
__________________
94 Lightning
86 F150
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
