Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-26-2008, 05:36 PM
drb1956 drb1956 is offline
drb1956 is starting off with a positive reputation.
Question Driving lights ?
Haven't done any reseach on this yet(bad weather), but does any know if the wiring is installed from the factory, even if you don't have factory installed driving lights.? We bought an XLS, w/o lights, and I was wondering if the wiring is in the wiring loom, so that I wouldn't have to run my own wiring. And is it under the dash also?? I didn't think about the lamps when we bought it, as I want to buy the factory kit when the weather changes(spring)...
__________________
'99 Ranger XLT Sport (LB) Amazon Green
2.5L, M5OD, 3.73, 130,125
'07 Escape XLS 2.3L (FWD) Auto. 47,000 (Wifes)
  #2 (permalink)
Old 12-26-2008, 09:06 PM
DSofT DSofT is offline
DSofT is starting off with a positive reputation.
US and Canadian wiring are different, US version has no DRL wire going from under dashboard to engine compartment, no DRL module and no DRL relay.
  #3 (permalink)
Old 12-27-2008, 08:31 PM
Red face Wiring??
Don't they make the XLT version at the K.C. plant also. Those seem to have driving lamps installed from the factory.. I just figured if they come off the same assembly line, Ford would make it easy on themselves, and just use one loom for all...Didn't know there was a Canadian version??? Also, I.m not talking about Daytime Running Lights-Driving and/or Fog lamps is what I asked about..
__________________
  #4 (permalink)
Old 12-28-2008, 08:31 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
All Escapes are built at KC but that doesn't mean that they get the same parts. If it's like other assembly lines, they batch similiar builds in groups and change over as needed.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #5 (permalink)
Old 12-28-2008, 09:59 AM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold
I seem to remember a couple threads about people adding fog lights by purchasing all the parts and putting them on. I'm pretty certain it was on this site. Have you tried searching the forum?
__________________
Ray
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
  #6 (permalink)
Old 01-24-2009, 09:56 PM
93truck 93truck is offline
93truck is starting off with a positive reputation.
I put the fog/driving lamps on my 2002 xls. all wiring was there. i bought a ford switch and lamp assy and all was good
__________________
2005 f350 CC/LB/4X4 6.0l AT
  #7 (permalink)
Old 01-25-2009, 06:39 PM
Did you buy the Ford kit, or an aftermarket set-up?? Also, can I ask what you paid if its Ford?? Haven't done mine yet, but I will in the spring....
__________________
  #8 (permalink)
Old 01-25-2009, 07:31 PM
i just went to ford parts and bought each light and a switch, no kit. i got my parts at cost from a friend and spen about $100.00 . if i had to do t again i would try one of these pull-a- part junk yards that seem to be popping up all over and i bet the used parts would be $50.00 at best.
__________________
  #9 (permalink)
Old 01-28-2009, 05:03 PM
wj52083 wj52083 is offline
wj52083 is starting off with a positive reputation.
When you say "driving lights" are you referring to the automatic lights (on at dusk off at dawn)? I was wondering if there was a factory harness installed on the escapes as well. That way you could just go to a junkyard and get the switch and photoelectric sensor. I know with my 99 F150 the harness is already there for auto lamps. If not, this is a really good alternative that I'm looking into: Advanced Headlamp Control Module
  #10 (permalink)
Old 01-29-2009, 07:06 AM
no, I am talking about the "fog / driving lights" mounted in the bumper. they only come on with your headlights on
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
