Bank 1, Bank 2 too rich - Ford Truck Enthusiasts Forums
Old 12-26-2008, 02:01 PM
chabre chabre is offline
chabre is starting off with a positive reputation.
hey guys...So my moms winter beater needs some love. I need to get it through emissions (they just read codes in CT now)..anyways, I have po172, po175 that came back. Now it has a fresh tune up (did it beginning of December, also has new O2 (all 4). new IAC (start/stall issue)...I was a Ford tech, but right now, all my diag tools are not near where I am. I'm kinda thinking MAF, or fuel pressure...anyone have similar issues?It runs great with the tune up, etc...just won't pass with the light on.
oh, and its a 99 exploder, eddie bauer edition with a 5.0
Old 12-26-2008, 10:51 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
could be MAF sensor needs cleaned, or could be vacuum leak causing the "rich fuel" code. i would look for vacuum leaks on small hoses and PVC valve first- thats the easy thing. pull each hose off the tubes and see if any are cracked, hard, or loose on the tubes.
Old 12-26-2008, 11:51 PM
thanks for the reply..went through all that, cleaned, etc...almost 20 miles with no light so far...see how it goes tomm. Probably go over it all once more. Thanks again
Old 12-27-2008, 10:12 AM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
MikeB 88 is gaining momentum as a positive member of FTE.
Same thing happened with our '01 Sable. wound up having to change the PVC hose, as it was collapsed and cracked.
Old 12-27-2008, 07:28 PM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
Lets think about this. "Bank 1 & 2 RICH".... How is a vacuum leak going to set this code. Rich= too much fuel. The system is seeing more fuel in the exhaust then it wants. So in other words your fuel trims are below -10 or so. You need to be looking at either high fuel pressure, intake restriction(i.e..air filter plugged), or possible incomplete combustion. Could be a stuck open injector, but if your not having any misfire problems or codes, chances are thats not your issue. You might also want to see what your MAF is reading. PCM might think it's getting more air then it actually is and lengthening your injector pulses causing a rich fuel mixture. Vacuum leaks are going to cause LEAN codes because of the extra unmetered air being sucked into the cylinders.
I can't remember the years, but some of the explorers also had issues with hanging injectors during cold starts. They would free themselves as the engine warmed up. But being both banks are rich, chances are this is not your issue.
Old 12-30-2008, 12:55 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
I concur with wilber, either a MAF, FPR or air filter, doubt injector as both banks are affected.
Old 03-07-2009, 12:08 AM
babylove0003's Avatar
babylove0003 babylove0003 is offline
babylove0003 is starting off with a positive reputation.
How do you get bank 1 too rich and bank 2 too lean? what is the cause of this anyone know?
Old 07-28-2009, 11:53 AM
osheam osheam is offline
osheam is starting off with a positive reputation.
Possible Solution
Vacuum leak most likely; check the elbow vacuum connections.
trouble codes bcupac53 Ranger & B-Series 5 11-21-2016 07:47 PM
03 Expedition stalling, rough idle, etc.. sniper7369 1997-2006 Expedition & Navigator 9 01-23-2014 10:05 PM
Diagnosing my first 6.0 big ole ford 6.0L Power Stroke Diesel 8 10-07-2013 08:01 PM
Glow Plugs Left Bank Pappyoutlaw44 1999 - 2003 7.3L Power Stroke Diesel 12 04-27-2012 09:23 PM
99 svt f150 lightning codes oss150svt Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 8 11-14-2010 11:28 PM
Tags
2000, 2003, 40, bank, banks, code, explorer, ford, lean, mercury, mountaineer, po172, po175, ranger, rich, setting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
