off road fuel
It's the exact same fuel as onroad except it isn't taxed and is dyed red. Plus it can get you in BIG trouble if you get caught using it. I wouldn't make a habit of it, but people get away with running it. If my options were put offroad fuel in the tank or run out of fuel I'd put in the offroad, but other than that I'd just find some clear (on-road) LSD.
not sure in your state but in mo if you are running farm tags on your truck you can run #2, why are you wanting to run #2, if its for lubricity you need to check with your state regulations, mo requires ultra low diesel to maintain the same lubricity as low sulfer, i think ks does not, i have heard of guys adding motor oil or atf to thier fuel.
Here the red and the clear are exactly the same. They come out of the same tank and color is added at the station. Around here they set up roadside spot check for red diesel. The first offense is $1,000. The second can be $1,000/gal or $25,000 whichever is more. It generally is less, but if you were to get obnoxious to the officer he could give you the higher fine, a couple of the local loggers got around $2,500 second time around. It seems to me like pretty expensive diesel but the guys that got caught said they still come out ahead after running untaxed fuel for over 10 years.
Offroad is the same as the LSD. It's just dyed red.
