Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 12-26-2008, 12:33 AM
sckootter16's Avatar
sckootter16 sckootter16 is offline
Garage is empty, add now
sckootter16 is starting off with a positive reputation.
Unhappy need help with some info
Ok hopefully the guys and girls in pa can help me I am wanting to rebuild a 351w to produce around 400 horse but i do not know what component configuration to use is there any web sight i can go to that will give me good info or does anyone know what the best configuration is the get around 400 horse out of a 351w. by the way it is going in my 81 f-150 4x4. please help and make me proud to live in pennsylvania thanx.
  #2 (permalink)
Old 12-26-2008, 01:31 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Try the SB forums, and try reading the replies to your prior posts. You have posted this same question in several spots. The engine forums are where you will find the info.
http://www.ford-trucks.com/forums/80...nd-winsor.html
  #3 (permalink)
Old 01-02-2009, 12:51 AM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
build a 408 stroker motor out of it, your block with the 408 stroker rotating assembly. 10 to one pistons, trickflow twisted wedge heads, victor intake, 750 speed demon, 1.6 roller rockers, comp cams camshaft(call them for the matching cam). that will get you to 400 and some,
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #4 (permalink)
Old 01-06-2009, 08:54 AM
jpb222 jpb222 is offline
jpb222 is starting off with a positive reputation.
when I built the 351W for my 52 f-1
I got a 393 kit from these guys
Go Fast Stuff - Kits
I then had is balanced and got a custom solid lifter cam ground from comp cams and ran world products cast iron windsor SR heads with roller rockers and used a wieand stealth intake with an edlebrock 600 cfm carb.
IT didn't cost me much cash but is a GREAT running motor.
it runs good enought to grenade 3 trannys and 3 rearends.....I now have a full roller dynamic racing transmission that is holding up and am going to swap in an n-case 9" center section as soon as I find a locker for it (right now I am running a lincoln 9 3/8" rear)
__________________
two restored 1979's a 350 4x4 and a low mile 150 2wd
three 66-77 EB's, one restoration, and 2 rock buggies
three 48-52 f-1 pickups, one sleeper, one 4x4 DD and one restoration project
  #5 (permalink)
Old 01-06-2009, 11:42 AM
here is a video I took a while back when I first put it in the truck.
It runs a bit quicker now since I have made adjustments and other upgrades to it.
Click the image to open in full size.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
