stumbling on acceleration - Ford Truck Enthusiasts Forums
Old 12-25-2008, 11:37 PM
dsljay dsljay is offline
dsljay is starting off with a positive reputation.
My wife 2002 Mountianeer with 66K, awd, v6,and auto stumbles when I try to accelerate while moving. EX. if I am driving about 45mph and I try to increase my speed, the car stumbles or shutters for a second or two then it accelerates fine. I don't have a check engine light on, yet.
Any ideas what could cause this problem?
Thanks,Jay
Old 12-27-2008, 07:41 PM
Paulford8's Avatar
Paulford8 Paulford8 is offline
Paulford8 is starting off with a positive reputation.
This start all the sudden? I have had two similar situations.... Water vapor in your fuel lines could cause stumbling. Have you tried a dryer like Heat?
I had a 99 Ranger with a 3.0 that stumbled off and on for months while I chased my tail around. Problem ended up being crap in my fuel injectors. In this case I ended up cleaning some with carb cleaning and re-installing, and replacing 2 that did not read in the normal resistance range (you can check this with a multi-meter if know what resistance is suppose to be).
Fuel filter changed recently? That is another easy possibility.... Good Luck!
Old 12-30-2008, 07:56 AM
dan8052's Avatar
dan8052 dan8052 is offline
dan8052 is starting off with a positive reputation.
All I can say is... "Red-Line S1 Complete" fuel system cleaner! Good Luck!
Old 12-30-2008, 09:46 AM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Actually, two of my vehicle at one time would stumble, and both had the same issue, a dirty/fouled MAF sensor. If the MAF element can't give you accurate information about the amount of air going into the engine, the computer will not add enough fuel, causing lack of power and stumble/hesitation. As the airflow increases, the inaccuracy is still there, but becomes less significant or noticeable.
Old 12-31-2008, 03:14 AM
srercrcr srercrcr is offline
srercrcr is starting off with a positive reputation.
Hows your prev maint doing? Cleaned throttle body valve recently?
Old 12-31-2008, 08:56 AM
Here is where I'm at. I'm trying to change the gas filter,BUT, I can't get the gas line off on the side that needs the tool to remove. I have the tool, BUT I just can't get it off. There must be a trick. Help!!!
Also, what is the correct way to clean the throttle body? Can I just spray it or do I need to remove a sensor first. Help, i'm in over my head.
Thanks, Jay
Old 01-01-2009, 03:26 AM
Remove the big rubber air inlet hose. Spray carb cleaner on the valve just inside the body. Use your finger, flush with the cleaner. Do the front, the edge, and do the back side. Spray on up inside the body. You'll be amazed how dirty it gets. I lay rags on the serp belt so the cleaner won't contact it.
Old 01-01-2009, 09:42 AM
Thanks, Steve. I'll give that a shot.
Has anyone tried Seafoam on there intake? If so, which vacuum line did you use, or does it matter?
Also, I changed the fuel filter. It may have been the OE.
Thanks again, Jay
Old 01-01-2009, 10:46 AM
Paulford8's Avatar
Thanks, Jay
Jay, Srercrcr was right on with the TB. I spray the crap out of mine every once in a while and always get tons of dirt out.
Using that fuel filter tool can be tricky. Every time I change one it takes me a couple tries to get then apart!
Don't feel overwhelmed! Nobody on this board started out knowing how to make repairs. Most learned like you.... Had a problem and went after it!
Old 01-01-2009, 11:06 AM
Update
I changed the gas filter and the car runs about 95% better. I'll clean the TB this weekend. For now, we're off to friends for a traditional new years day dinner of pork and sauerkraut.
Happy new year to all.
Thanks for the help and support, Jay
Old 12-27-2009, 03:41 PM
bobward bobward is offline
bobward is starting off with a positive reputation.
BEEE CAREFUL which spray you use in the intae on the throttle body. MAKE SURE you only use a spray safe for Mass Air Flow Sensors.
Did this to my Taurus and wound up damaging the MAF. Immediately got the check engine light with codes. Had to replace MAF as regular carb cleaner damaged the MAF.
Old 04-11-2010, 04:57 PM
Sikdmax Sikdmax is offline
Sikdmax is starting off with a positive reputation.
Has anyone tried seafoaming? Ive tried that with good results.
429 w edelbrock acceleration stumble maytea 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-29-2016 10:14 AM
electric choke 79lownlong 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-06-2014 05:28 PM
Stumbling acceleration Jklnhyd 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-13-2014 10:16 PM
Stumble Under Load jd1083 1999 to 2016 Super Duty 7 06-10-2011 10:23 PM
Engine Stumbling? VQ2Fast4U 1999 - 2003 7.3L Power Stroke Diesel 13 11-13-2006 11:46 PM
Tags
1991, 1994, 2002, 42, acceleration, engine, escape, explorer, f150, ford, hesitation, pressing, stumbles, stumbling, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
