HELP!! with 1965 stock drum brk problem - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 12-25-2008, 04:47 PM
Eston Newbern Eston Newbern is offline
Eston Newbern is starting off with a positive reputation.
I'll be brief
Truck sat for 5 years without moving
I replaced
ALL shoes
ALL wheel cylinders
Master cylinder
The REAR wheel cylinders are NOT retracting AFTER letting OFF the pedal, brakes remain ON.
I have NOT yet pulled the front drums to see if I have the same problem.
I was told the RUBBER/FLEX hose going FROM the metal line to the junction ( at rear ) was the problem< I replaced that and still have the problem.
What is the function of the line on the junction that has a rubber line going up to frame? Is it a bleeder?
ANY suggestions? I really don't have the $$ to tow it to a shop, I have purchased the front hoses to put on latter.
HELP
Old 12-31-2008, 04:43 PM
3broncocrazy's Avatar
3broncocrazy 3broncocrazy is offline
3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.
you might have to ask this over in the tech forum, I have no idea, not a good brake man....
Old 01-02-2009, 01:04 AM
tin-man's Avatar
tin-man tin-man is offline
tin-man is a name known to alltin-man is a name known to alltin-man is a name known to alltin-man is a name known to alltin-man is a name known to alltin-man is a name known to all
Welcome to FTE Eston, Do you have springs that pull the shoes back in after you let off the brake?
Old 01-02-2009, 08:37 AM
exidenick exidenick is offline
exidenick is starting off with a positive reputation.
Here are a couple of things that I have found
1) did you repace the springs they lose tension sitting for extended periods
2) did you clean and lube the contact pads on the backing plate. Thet get corroded and will not allow the shoe to retract properly
Where are you located maybe someone can help you
Old 01-02-2009, 11:39 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
Along with the contact points you need to lube the adjusters, threads and caps.
Question? how far can you pull the e-brake handle back?
If you only get a few clicks before it stops, loosen the adjusters so the brakes are not so tight.
Old 01-03-2009, 12:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Bill, the brake adjusters really have nothing to do with how tight the emergency brake is.
If you back off the adjusters to loosen the cables, it may work, but it's not the correct way to do it.
There are three e-brake cables. Where the cable from the dash mounted e-brake control meets the two rear cables, there's an equalizer bar there that has an adjustable rod attached on it.
All three cables attach to the equalizer bar.
Tightning up the nut on the rod takes up the slack in the cables.
If the rear brake shoes were replaced, and someone forgot to re-adjust the cables, there's the problem.
I would not recommend using any lube anywhere inside the brake drums, because it could end on the brake shoes.
These trucks came from the factory with self adjusting brakes, which only work when the truck is backed up and the brake pedal applied.
Within a few short years, these adjusters become next to worthless because the self adjuster cables stretch.
More times than not, the cables snap, then the self adjuster cable guides bump around inside the drums, and may end up between the drums and the brake shoes, which when the brakes are applied, gouges the hell out of the drums.
NAPA used to sell a kit to replace those self adjusters.
The self adjusting system is the same thing as the cars used, but some of the parts are truck only.
btw: The OP has two threads on this topic. He asked what was the function of the tube that fits into the rear brake hose junction block. He thought it was some sort of bleeder.
I explained to him in the other thread that it's the rear axle vent, and it just passes thru the junction block and threads into the axle housing.
Rear Brake Line Fitting Size FordBoy2012 1997 - 2003 F150 1 10-06-2013 08:39 PM
Brake Proportioning Valve I.D & ???/69 F250 68horses 1967 - 1972 F-100 & Larger F-Series Trucks 0 11-15-2008 01:07 PM
Van eating wheel cylinders, again... fattmann Brakes, Steering, Suspension, Tires, & Wheels 5 06-26-2008 08:03 AM
Rear Axel Brake Junction Block netscaner 1987 - 1996 F150 & Larger F-Series Trucks 12 06-18-2007 09:07 PM
Tried to bleed rear breaks, no fluid in rear lines, need help irontruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-06-2005 03:45 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1965, 2000, adjustment, blockaxle, brake, brk, emerg, eston, ford, junction, newbern, rear, rubbers, truck, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
