1997 Windsor to 5.4 conversion
Hello all.
I have a project truck. It currently has a 4.6 Windsor engine with a rod out one side.
This truck has a Manual Transmission.
I did some research on the Net and got confused on the crankshaft bolts to flywheel.
Here is the info.. Let me know if this is correct..
1. 5.4 crank is 8 bolts?
2. Romeo engine is 8 bolts?
3. Windsor crank has 6 bolts?
4. Does the Manual flywheel have both bolt patterns?
So the question is.. "What Manual Flywheel will bolt to the 5.4 block?"
The info I found on the Net stated using the Windsor Flywheel on the 5.4 engine but how could that work?
Thank You!
Thank You!
bobbyray1963
02-02-2015 08:12 PM
BushyTea
01-25-2015 07:14 PM
RiverReaper
11-18-2014 04:16 PM
liftnw8z
1997 - 2003 F150
10-08-2014 01:22 PM
