Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-30-2000, 09:51 PM
bman is starting off with a positive reputation.
melted Radius Arm Bushing
I have a 94 F-150 SC 4x4, I have had to replace the right radius arm bushing 3 times in the last 6 years. Has anyone else experienced this? If so is there a fix.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-30-2000, 10:00 PM
Nathan is starting off with a positive reputation.
Is your exhaust close to this bushing? If so, a simple heat shield made from sheet metal may be an inexpensive fix.
Nathan
  #3 (permalink)
Old 02-04-2001, 03:18 PM
lr lr is offline
lr is starting off with a positive reputation.
  #4 (permalink)
Old 03-24-2001, 11:42 PM
alumiford is starting off with a positive reputation.
Had the same problem with my 95 shortbed. Radius arm bushing is located extremely close to the rear cat. on the exhaust on the passenger side of the truck. Have you tried to replace with an aftermarket bushing? Maybe something from Energy Suspensions?, or other reputable aftermaarket suspension bushing company? Good Luck!
  #5 (permalink)
Old 03-25-2001, 09:28 AM
JoeB is starting off with a positive reputation.
I had the same problem. I replaced mine with energy Suspension bushings and haven't had the problem since. I don't know why Ford didn't put a heat shield on the lighter duty trucks. My friend has a 94 F350 5.8,E4OD(2WD)and his truck has an extra heat shield between the cat and radius arm bushing. Maybe you could pick one of those up from a salvage yard.
Joe
94 Bronco XLT,5.8,E4OD
__________________
Joe
94 Bronco,5.8 E4OD, 4"skyjacker 2"body lift,35"Mud Terrains,4.10 gears,K&N FIPK and Custom SS exhaust,BDS Extended Radius Arms.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
