Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-24-2008, 06:37 PM
philipk philipk is offline
philipk is starting off with a positive reputation.
washers don't work
I have a 2002 ford escape and the washers don't work.
What fuse are the washers on?
How do I get at the washer itself if it does need replacing?
Thanks! Kevin
  #2 (permalink)
Old 12-24-2008, 07:36 PM
V X V X is offline
V X is starting off with a positive reputation.
Silly ? but are they frozen?
Mine freeze up more than I care for.
__________________
V X
I'd CEO Ford and pay them a buck.
  #3 (permalink)
Old 12-24-2008, 08:25 PM
I don't think so. Also I don't hear the pump working. Even if the lines are clogged the pump should still make some noise, right?
  #4 (permalink)
Old 12-24-2008, 10:29 PM
wptski wptski is online now
wptski is starting off with a positive reputation.
Nope! When mine don't work because the liquid is frozen, I hear nothing.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #5 (permalink)
Old 12-25-2008, 02:03 AM
It's park in a heated garage.
How can I test the pump?
  #6 (permalink)
Old 12-25-2008, 09:55 AM
Trace the hoses to back "wherever" it is and disconnect them. Try the washer, if you don't hear it run then, the pump is either defective or no power to it. You'll need a meter of some kind then to see if your getting power to it. You could ckeck the fuses to see if its on a fuse by itself too.
My 09 manual doesn't even list a fuse for the washer pump!! Unless it's vacuum operated but it's got a good hum to it when pumping which sounds more electric than vacuum operated.
__________________
Bill
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
