Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > New Mexico Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Mexico Chapter Join Chapter, Leader: CelticDevilDog
  #1 (permalink)
Old 12-24-2008, 04:01 PM
santi2322's Avatar
santi2322 santi2322 is offline
Garage is empty, add now
santi2322 is starting off with a positive reputation.
Np435
Anybody here in NM have an NP435 4-speed they want to sell for a 1966 F-100?? Mine is toast and I need to get a new one. If not, anyone know who sells them around Albuquerque besides the junk yards? Thanks a lot.
  #2 (permalink)
Old 01-06-2009, 09:46 AM
F0rdFre@K's Avatar
F0rdFre@K F0rdFre@K is online now
2008 Ford F-350
F0rdFre@K is gaining momentum as a positive member of FTE.
Wish I could help buddy. Only one I came across was for my Early Bronco. Ended up swapping in a C4 instead of the NP435 because I drove that one every day to work. Didn't need the granny gear on a daily driver.
Sold it to my buddy. Rebuilt it and put it in his EB.
I may still have some contacts from the local EB community (I used to run NMEB.net) and see if anyone knows of one locally?
Also, try calling Joe at El Mexicano Truck Salvage. Tell him Eddie sent you. I doubt he has anything that old. But, may be able to point you in the right direction?
__________________
Fierce Off Road Destroyer - 08 Ford F350 FX4 Crew Cab Black on Black w/ 8" Lift, 38x13.5x20" Nittos on XD wheels. Uniden CB, Wilson 1000 and a PA. Air horns w/ compressor and tank.
Fierce Off Road Destroyer - 73 Ford Bronco Roadster. 302 w/ "mods", C4, D20, D44, 9", 6 Point Cage, Rancho Lift, 35x12.5x15" Mud Tires on Aluminum Rims
  #3 (permalink)
Old 01-20-2009, 11:24 PM
santi2322's Avatar
Thanks a lot. Any help at this point is very helpful. I can't seem to find one anywhere. I will try El Mexicano. Also, how difficult was it to convert to the C4? I was thinking about going to a C6 but it seems like it is a lot of work. Do you know if a column shifter can be converted to the floor shifter? Thanks again for the help.
  #4 (permalink)
Old 01-21-2009, 10:51 AM
F0rdFre@K's Avatar
2008 Ford F-350
When I swapped from my 3 speed to my C4, I pulled all the clutch assembly out of my Bronco. Had to disassemble the pedal assembly to get the clutch pedal out. That was probably the most difficult part. But, still fairly easy. Then, the Auto is a plug and play. Only thing to concern yourself with is the shifter. I ran the B&M Mega Shifter on the floor. Came out SWEEEET!!! Has a ratchet shift for quick shifting without over shifting if you like to race.
I have a C4-D20 adapter in my storage. Honestly, it's BEST to find a C4-D20 already assembled (if that's the route you are going). But, if you find your self hunting for parts... let me know...
__________________
  #5 (permalink)
Old 01-21-2009, 02:18 PM
santi2322's Avatar
I called El Mexicano and they didn't know of anybody that would have that tranny and they didn't have one. As far as a plug and play like you said, other people on the forum told me I would need to shorten my axle, get transmission cooling lines, a kickdown linkage, and something else I think. Is that not true or does some of it need to be done? Thanks again for the help.
  #6 (permalink)
Old 01-29-2009, 06:33 AM
BChance's Avatar
BChance BChance is offline
BChance is starting off with a positive reputation.
$200 .......................Ford Motor & 4 Speed Transmission
Dunno if it's the right one... but maybe...
__________________
BChance
Los Alamos, NM
JOIN NEW MEXICO CHAPTER HERE!
"Oderint Dum Metuant"
Tags
435, bm, c4, disassemble, np, np435
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
