02 Explorer P1400 code? - Ford Truck Enthusiasts Forums
Old 12-24-2008, 02:53 PM
Rob.D's Avatar
Rob.D Rob.D is offline
Rob.D is starting off with a positive reputation.
Well just had my wifes 02 XLT 4.6, V8, 4x4 Explorer at the dealer ship for a regulator assembly that controls the driver side window. It quite working and I also had the right rear wheel bearing replaced. Well I went to drive it this morning, which I rarely do and the service engine light came on while driving. I pulled into an Auto Zone to pull the code. P1400 Aux Emission Control. They had no idea what it would be! I was hoping someone here could help.
Old 12-24-2008, 03:37 PM
Rob.D's Avatar
I guess I should have done a search first. It looks like the DPFE sensor is the place to start with the P1400 code. My local Napa is closed today so I will try them on Friday. What does DPFE stand for? Not even sure what it looks like & any tips on changing one out? Thanks
Old 12-25-2008, 06:49 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
I think you are on the right track. What you are looking for is the Differential Pressure Feedback Electronic sensor.
Never had to mess with one so don`t know where it is but as I understand it you unplug one and plug the new one in. Good luck.
Old 12-25-2008, 08:20 AM
tommyleea tommyleea is offline
tommyleea is starting off with a positive reputation.
Quote:
Have NAPA read your code so you can verify it.
Old 12-25-2008, 08:45 AM
Rob.D's Avatar
Quote:
I already had AutoZone read the code. What would Napa be able to tell me differently? Thanks
Old 12-25-2008, 09:19 AM
Autozone has DPFE sensors. It is a common Ford problem.
Old 12-26-2008, 11:11 AM
Rob.D's Avatar
Installed new DFFE sensor, all seems well. Thanks for the help guys
Old 12-26-2008, 05:49 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
When it happens again buy a Motorcraft DPFE............
Old 12-27-2008, 06:44 PM
Rob.D's Avatar
Quote:
I ended up with a Napa. What's the benefit of the Motorcraft?
Old 12-27-2008, 06:51 PM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
It won't fail in a month like your napa part will...
Old 12-27-2008, 06:54 PM
ncranchero's Avatar
I usually hang out in the 97-03 F150 forums. These models are famous for DPFE issues and the experience there indicates that the Motorcraft sensors greatly outlast the NAPA/AZ/etc replacements.
Old 12-27-2008, 07:06 PM
Rob.D's Avatar
Now Ya Tell Me!!
Old 12-27-2008, 07:34 PM
ncranchero's Avatar
Now Ya Tell Me!!
Sorry I didn't catch you in time. You're good for the present but your NAPA version will fail much sooner than the Motorcraft. I'm a newbie on the Exploder forums, don't have one yet but planning to.
Old 12-28-2008, 07:14 AM
Should have purchased one at Autozone, since you were there anyway.
Old 12-28-2008, 07:55 AM
ncranchero's Avatar
Looking to see if AutoZone had MOTORCRAFT (or any) sensors returned this:
EGR Valve Pressure Sensor
We're sorry, but there are no results in this parts category for your 2002 Ford Truck Explorer 4WD 4.6L EFI .
Buy ONLY Motorcraft DPFE Sensors which would be:
DPFE4 EGR Pressure Sensor Ford # 4U7E-9J460AA
You can look up your MOTORCRAFT parts here:
http://www.motorcraft.com/default.asp?T=3&PageID=0
or from one of the vendors here on FTE:
Silver State Ford Parts Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Description Year MSRP Price Core Price Your Price
Pressure sensor 02-03 $76.40 $40.67
Th!nk Parts Guy
Pressure sensor 02-03 $76.40 $41.26
Help with trouble codes RJL1 1987 - 1996 F150 & Larger F-Series Trucks 4 12-11-2016 09:49 AM
P0263 cylinder#1 code nufan4ever 6.0L Power Stroke Diesel 16 09-14-2014 09:21 PM
Need help with P1400 code (2000 Explorer) ImNotABotOMG Explorer, Sport Trac, Mountaineer & Aviator 5 08-12-2014 06:44 AM
02 ranger p1400 code bit422 Ranger & B-Series 2 07-16-2009 09:22 AM
OBD II Code, P1400 Gunner Thomas 1999 to 2016 Super Duty 6 02-24-2004 09:56 AM
Tags
02, 4u7e9j460aa, aux, code, control, dpfe4, emission, engine, explorer, ford, motorcraft, p1400, parts, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
