Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2007 and Newer Expedition and Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
Is F-150 Still King?
  #1 (permalink)
Old 12-23-2008, 03:09 PM
sulconst2 sulconst2 is offline
sulconst2 is starting off with a positive reputation.
07 exp died while driving
hey all, mostly view the v-10 forum but wifes 07 expedition with 42k took a dump while cruising 60mph. said it felt like it went into limp mode then when she pulled over it died. put it in park and no crank. all the warning lights came on the dash when key turned. i get there and notice the PATS warning light is blinking. seemed like the key lost its program? pulled the cables from battery for a few minutes. went to start and it sporadically turned over but no start. hit the fuel reset button, no good. pulled the key out and noticed some lights stayed lit on the dash! figure this is a PCM issue. got it towed to the dealer. he wants both keys so he can reprogram. OK. said he got it started 3 seperate times but it shut down each time. wants to install a starter! for 450! if thats not it then install the PCM which is under warranty.
i questioned that the PCM has about 4 fuses to protect it and he says that its a surge not a fault to ground.
I'm still think its the PATS system.
looking for some input before i OK the starter.
thanks in advance
SUL
cc: electrical forum
__________________
john sullivan
2000 f250 sd 2wd v10
4.30 rear
ext cab long bed
sctb 96-98 accufab TB
aem brute force intake
superchip 1715 tuner
borla headers and split side
zoodad mod
i-rotors drilled and slotted
  #2 (permalink)
Old 12-23-2008, 03:23 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is starting off with a positive reputation.
Starter? HEll no. Why would a starter cause it to shut down? Waste of money on your part.
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #3 (permalink)
Old 01-24-2009, 05:15 PM
Freak4Ford's Avatar
Freak4Ford Freak4Ford is offline
Freak4Ford is starting off with a positive reputation.
The starter going bad would not cause a shutdown condition. Was it raining when it shut down? What was the final determination of the cause?
__________________
2004 Navigator Ultimate 4wd
Superchips Tuner
Aero Exhaust S/S Muffler
MagnaFlow S/S Resonator
22" wheels
305/40 tires
  #4 (permalink)
Old 01-25-2009, 08:09 AM
i'll look up the reciept which shows the codes but paid for a rebuilt starter then warranty covered the pcm.
they basically said if i didnt want the starter replaced then pull the car out of their lot. wasnt happy but it wasnt worth another tow.
__________________
john sullivan
4.30 rear
ext cab long bed
zoodad mod
  #5 (permalink)
Old 01-25-2009, 06:16 PM
Freak4Ford's Avatar
If the warranty covered the pcm, why would it not cover the starter? I would get Ford involved on this one. Seems the warranty should have covered everything.
__________________
Superchips Tuner
22" wheels
305/40 tires
  #6 (permalink)
Old 01-25-2009, 07:24 PM
carbonmetallic carbonmetallic is offline
carbonmetallic is starting off with a positive reputation.
I had a similar issue, but mine was related to a valve in the transmission. Basically the transmission would overheat which would cause the engine to basically shutdown no matter how much gas you would give it. Then when I got to lower speeds the truck just died and would not start. I first thought it was the battery and tried jumping it with no luck. The only thing that worked was to let is sit overnight. Then the next day it was like nothing ever happended, other than all the lights on the dash were still lit up, thank god, otherwise ford would have never figured it out. Their service departments done know what to do if the computer isnt fuctioning correctly. The valve was not operating correctly, took ford 7 times to fix it correctly, good luck. They tried fixing everything but what was actually wrong, even after I told them exactly what it was doing. Dealerships and ford customer service suck, i had to send ford a letter threatening lemon law to get them to fix it correctly.
__________________
07 Ford Expedition Eddie Bauer
K&N drop in filter
Truxxx Leveling kit
285/70/17 Hankook Dynapro ATM RF10
SCT X3 Custom Tuned by Mike at 5 Star Tuning
  #7 (permalink)
Old 01-26-2009, 09:59 AM
Freak4Ford's Avatar
Did Ford replace the transmission or just repair the stuck valve in the transmission?
__________________
Superchips Tuner
22" wheels
305/40 tires
  #8 (permalink)
Old 01-26-2009, 10:41 AM
Quote:
just the stuck valve, they had already changed out the full valve body twice thinking it was the problem. I tried to get a whole new transmission they said it wasnt damaged any......did i mention there customer service sucks!! Of course they changed out the fluid, I even tried to get them to add a transmission dipstick (which is idiotic that our trucks dont have one).
Good luck getting it resolved. You are out of your basic warranty, but the powertrain carries a 60K warranty I believe.
__________________
K&N drop in filter
Truxxx Leveling kit
  #9 (permalink)
Old 01-26-2009, 08:26 PM
Freak4Ford's Avatar
Wow! I didn't know that Ford is now omitting the transmission dipsticks. How are you supposed to check your fluid level?
__________________
Superchips Tuner
22" wheels
305/40 tires
  #10 (permalink)
Old 01-27-2009, 06:17 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
My '02 Explorer also lacks a transmission dipstick. Pretty normal Ford feature.
-- Chuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
