Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-23-2008, 10:34 AM
pie man pie man is offline
pie man is starting off with a positive reputation.
85 ford 6.9 4x4 4spd oil consumption
i have a 85 f250 4x4 4spd with roughly 100.000 miles when driving around town i does not seem too use oil but when on the highway runing 60 mph and just under 2500 rpms it uses oil, from louisville kentucky to youngstown ohio i use about a gallon of oil is this normal or do i have a problem and if so is there a quick fix ??????? thank you for any help
  #2 (permalink)
Old 12-26-2008, 02:41 PM
seizure911 seizure911 is offline
seizure911 is starting off with a positive reputation.
you might have better luck getting an answer to this question in the pre powerstroke diesel forum
__________________
'93 F250HD XLT 4X4 7.3 NA, ZF5, 4.10's, 265/70-16 bfg at's summer, 235-85-16 studded hakkas winter, gear vendors od
  #3 (permalink)
Old 12-26-2008, 09:26 PM
starmilt starmilt is offline
starmilt is gaining momentum as a positive member of FTE. starmilt is gaining momentum as a positive member of FTE.
Pieman it is not normal your cdr valve might need servicing. Come over to the idi prepowerstroke site there is a lot of good info and folks on it.
  #4 (permalink)
Old 12-30-2008, 03:08 AM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 is starting off with a positive reputation.
ya listen to star 2500 rpm thats hight for a 6.9 u realy should not run it that high
  #5 (permalink)
Old 01-01-2009, 12:21 PM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
Quote:
I second everything he says. The CDR is just behind the air intake stack on the intake manifold.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
