Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-23-2008, 11:10 AM
EricJ EricJ is offline
EricJ is starting off with a positive reputation.
Frame build
anyone built a frame for their Bronco? I've been unsucessfully looking for a good frame in the New England area,(surprise), so I figured I'd build my own, looks like a pretty simple frame rail made out of a 3x4 box. I can buy a 3x4 rectangular tubing in 1/4" for about 300 bux and it looks like it only has 8 bends, so it shouldn't be to hard to fabricate.
Unless anyone has a better idea.
  #2 (permalink)
Old 12-23-2008, 02:48 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
There are still plenty of straight, rust free frames available. Call the Bronco suppliers for a price quote and shipping costs. With the price of steel these days, it would probably still be cheaper to buy one.
Unless you have some experience with building frames and you are a very competent welder, I wouldn't do it. Even a 1/16" off on a measurement can cause ill handling and problems with fitting parts.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 12-23-2008, 04:03 PM
Jason
I am capable, and I have the tools and the hobby shop so it's doable. And although it would be easier to buy, I can't see it being cost effective with the price of shipping these days. ANd I'd have to buy it sight unseen which makes it iffy at best. At least if I build it myself, it will be better than the original 1/8" steel, and I'll know it's rustfree inside and out. I'd like this to last til I die, and I'm only 55 now, so it's gotta go atleast 2 more years
  #4 (permalink)
Old 12-23-2008, 07:44 PM
RCrawler's Avatar
If you have the skills and the tools, then go for it. It is a major undertaking and there will be A LOT of man hours involved.
The first thing you'll need to do is come up with some measurements from yours and build a jig.
Jason
__________________
  #5 (permalink)
Old 12-23-2008, 10:44 PM
dodmort's Avatar
dodmort dodmort is offline
dodmort is starting off with a positive reputation.
Quote:
Jeeze
Ill be 56 in March...
so I got one more year...
well
there it goes
Been hand fabing out 68 m715 Ford powered for a year now...
Things look bleak...
Guess I better get out and get to welding..
ohh
BTW
yes it is easier to use nice clean metal stuff than try to work around old dirty or rusty metal stuff.
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Guns, Guns, Guns......."Clarence Boddicker" Robocop circa 1987
  #6 (permalink)
Old 12-24-2008, 08:06 AM
Jason
actually I was thinking I'd measure up all the brackets, then grind the rivets off and pull the side rails off, and use them for the template. The brackets all look good, so I can sand blast tem and re-use them on the new rails.
My theory is to cut threw the new rectangular tubing every 1/4 inch at the bends but only cut 3 sides, leaving the inside of the bend intact, bend the rail, then weld in the cuts. And If I don't like the looks of it I may fishplate the sides and top of the bend.
It looks like there are only 8 bends, so it shouldn't be too bad to do.
  #7 (permalink)
Old 12-24-2008, 01:55 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Go for it! Make sure you document it w/pictures. Personally I'd love to follow your progress. I love fab work, just was unable to start learning till late in life. Too busy working for a living. Getting pretty good w/ sheet metal but my welding isn't good enough to trust my life on critical parts.
  #8 (permalink)
Old 12-24-2008, 04:12 PM
Quote:
I will, and you shouldn't let that stop you, if I build something and I don't trust my own welding on, I usually just tack weld it and let one of my welder buddies weld it up right. All the money is in the setup, after it's all tacked together the welding is quick and cheap.
  #9 (permalink)
Old 03-21-2009, 01:47 PM
ksmith203's Avatar
ksmith203 ksmith203 is offline
ksmith203 is gaining momentum as a positive member of FTE.
Well Prgress re[port please!
__________________
1969 N600 wrecker on its way. Frame and drive train done...Waiting on cab from sandblaster.
  #10 (permalink)
Old 03-22-2009, 05:09 PM
Quote:
I got slightly side tracked, I went into my shop with every intention of making room to tear the Bronco apart and realized all the stuff that was in my way could be assembled into a 46 Ford pickup. So I pulled the frame down from the ceiling and got it on the lift.
I've decided to put a 9" rear in it behind a 312 and a 3spd OD trany I have out of a 57ish t-bird.
So Far I have the 9" done, made new spring cradles and shock mounts and welded them on. Made and installed rear shock mounts outboard of the frame. And setup a rear swaybar I stole out of an early 80's bronco.
Now I have to attack the front end. That's a bit more complicated. I decided to stay with the straight axle, not sure if I'm gonna stay with manual steering or fab up a power unit for it, and I need to setup front shocks and a sway bar. The shocks look pretty straight forward, but the sway bar may be a bit tricky, not much room up there to play around.
Looks like it may be awhile before I start the little Bronco. But atleast I'm making progress on something
  #11 (permalink)
Old 03-23-2009, 09:14 PM
ksmith203's Avatar
Well atleast your keeping busy!
__________________
Tags
ford , m715
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
