replacement of ball joints on '93 F150 4x4 - Ford Truck Enthusiasts Forums
Old 05-02-2001, 09:54 PM
arapco arapco is offline
arapco is starting off with a positive reputation.
This is probably too fundamental question for this forum, but to replace the ball joints (upper and lower) on my F150, is it necessary to utilize a pickle-fork to release the tapers from the assembly?
Thank you for your patience in answering my question.
Ron
Old 05-06-2001, 02:44 PM
riley351 riley351 is offline
riley351 is starting off with a positive reputation.
Is your truck 2 or 4 wheel drive?? i know on my 95 f150 4x4 i had to have a special socket to use to get a nut out.(not sure if that is what your talking about) if your truck is 4x2 then im not for sure. hope this helps
95 f150 blue/white 351, auto 233,xxx miles 275/65.16 wild country RVT on Baha American Racing wheels.
Old 05-08-2001, 11:57 PM
slowtarget slowtarget is offline
slowtarget is starting off with a positive reputation.
Check out this link. Maybe it will answer some questions.
http://www.Off-Road.Com/ford/bigbroncos/tech/balljoint.html
Old 05-09-2001, 08:33 AM
Thank you for the website url. Looks like not much more than the combination of drive universal joint replacement coupled with standard ball joint r&r. Thanks again and will be reporting on progress after Saturday's work.
Ron
Old 05-09-2001, 09:30 AM
78f250 78f250 is offline
78f250 is starting off with a positive reputation.
Front Hub Replacement 99350Ron 1999 - 2003 7.3L Power Stroke Diesel 14 01-15-2010 06:58 PM
Axle Pivot Bushing priusron 1999 - 2003 7.3L Power Stroke Diesel 0 04-28-2009 03:13 PM
Ball joints r-kid 1999 to 2016 Super Duty 9 08-13-2005 05:58 AM
Ball Joint replacement Ron48 1999 to 2016 Super Duty 20 01-11-2005 08:55 PM
'93 F150 4x4 Oil Pan Replacement arapco 1987 - 1996 F150 & Larger F-Series Trucks 1 10-21-2000 08:30 PM
Tags
4x4, 93, ball, f150, joints, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
