2007 S.Crew latch system?
Old 12-22-2008, 05:06 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
My wife and I purchased a 2007 Expedition Limited last year and we absolutely fell in love with it. We really do like everything about it. So now we are in the market for a 2007 Super crew lariat but want to make sure that it has the rear seat LATCH system. Does it have a pair for each rear seat (6 total anchors) or is there only one set? Thanks for your help!
Old 12-22-2008, 06:08 PM
98greensi's Avatar
98greensi
98greensi is offline
my 05, has 2 sets on the outer seats, but we have an infant car seat in the middle seat that i used the anchors from in the inside of the two seats the oem seat belts function properly and the hold down (strap whatever you want to call it) does not get in the way of using the oem seat belts. also it has 3 anchors under the head rests for the booster seats
total of 4 on the bottom, and 3 on top
Old 12-22-2008, 06:20 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
2 different answers for you.
the 04 and a few 05 models have 3 seperate carseat latches (6 total) in the screw.
05+ have 2 seperate carseat latches (4 total) in the screw.
no sure why the change, wish the 05+ had the 6 of them though...I guess Ford figured that what 98greensi is doing is safe enough .
It's what I do in my 06 when needed. I usually just run the baby baby carseats on the outer edges.
FYI: You can easily fit 3 carseats in the backseat with about 4-6" of spacing between each carseat. I've got three in there right now. My 5yr old sits in the middle and "tends" the newborns. Probably gonna suck when they're all older though
