Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-22-2008, 11:13 AM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
Instruct for 08 Factory Nav use in Motion
Boys I'm doing this from memory, so please don't lynch me if I miss a step. Please try if interested and let me know results. If for some reason I miss a step, be patient, I will figure it out. My nav now allows me to access POI's while the vehicle is in motion. You will not find this on internet. I finally found out at work.
Here we go!
1. Take vehicle outside and agree to nav instructions. The gps needs to know its position.
2. Push hard nav button (on right side of radio). Go to your address book. Pick any of one of your saved addresses. Now that address is highlighted, look to right and push soft edit button. You will now see name of saved address.
3. Clear name of saved address and type in F-DEVELOP ON
(make sure to put space between DEVELOP and ON).
4. Now look to the upper left corner and you will see the word ADDRESS. Place your finger directly under the A and hold. If you do this right, the screen should change to the map screen.
5. Now push your hard menu button (on left side of radio). Across top of radio push soft SECURITY button. You have now entered security screen. You will see nothing in the right most corner of nav screen. Push your finger and hold in that position till the screen changes.
6. You now have entered a parameter screen. Locate DRIVING RESTRICTIONS release. When you push the button it should change to driving restrictions stop. Exit the screen by pushing the soft BACK button.
7. Congrats you have just programmed your factory nav radio. NOTE: Every time you turn your vehicle off, you will need to repeat steps 5 & 6.
Good luck and enjoy. If you choose to monkey around with your other parameters, do so at your own risk. I will not be responsible for your dealer service call. If you have any further questions, please pm me and I will do my best to help. This programming sequence should work for only the so called first generation navs. It will not work in the MY09, second generation. This has been used to reprogram many MY 07 and MY 08 Ford vehicles.
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP!!
10 Escape XLT
This isn't your father in law's Buick. Step back
and no one gets hurt!
  #2 (permalink)
Old 12-22-2008, 01:49 PM
mrfumanchu mrfumanchu is offline
mrfumanchu is starting off with a positive reputation.
my nav does appear to give an edit option when I select a saved address any suggestions ?
  #3 (permalink)
Old 12-22-2008, 01:52 PM
wiingnut's Avatar
on my nav, the only way the edit will show up is if I use the nav buton. It will not show up if I use Dest button.
__________________
10 Escape XLT
  #4 (permalink)
Old 12-24-2008, 10:04 AM
locolobo locolobo is offline
locolobo is starting off with a positive reputation.
Im new 2 site. I have been looking 4 info on this 4 a while. I will try over holiday. Thamk u
  #5 (permalink)
Old 12-26-2008, 11:42 AM
F250Wheels F250Wheels is offline
F250Wheels is starting off with a positive reputation.
I tested it and it works, Thanks, Wiingnut.
  #6 (permalink)
Old 12-26-2008, 04:59 PM
wiingnut's Avatar
Glad to hear. It was all recited on memory. Now that I know it works for sure, I'll contact a moderator and see if we a can get it added to tech folder.
__________________
10 Escape XLT
  #7 (permalink)
Old 12-26-2008, 05:19 PM
your instructions work great wiingnut. i had been looking 4 a long time.
  #8 (permalink)
Old 02-26-2009, 08:03 PM
Michaeloh Michaeloh is offline
Michaeloh is starting off with a positive reputation.
Hey Wingnut I tried your Nav unit fix. I got stuck on step 5, where there should have been nothing on the right corner of the screen there was the time. When I pushed the time it turned to the date. IOW I could not progress to the parameter screen. Any ideas?
  #9 (permalink)
Old 04-06-2009, 04:35 PM
MikeHGA79 MikeHGA79 is offline
MikeHGA79 is starting off with a positive reputation.
Anyone have ideas on how to watch DVD's while the vehicle is in motion?
(Yes, I know it's dangerous, but it's more for the passenger on a long roadtrip)
  #10 (permalink)
Old 04-06-2009, 04:50 PM
wiingnut's Avatar
I don't know of any way to do this with the fac nav. I know some of of the aftermarket one's can. If anyone knows how, please let me know.
__________________
10 Escape XLT
  #11 (permalink)
Old 04-06-2009, 04:54 PM
Yeah, I've seen some of those, but I'm not willing to shell out $350 to do that. They also unlock the rear audio features as well.
Cool stuff, just not worth the cost.
  #12 (permalink)
Old 04-15-2009, 09:59 PM
wiingnut's Avatar
I have confirmation the above instructions work with the MY07 as well. If someone can confirm any other MY please do.
__________________
10 Escape XLT
  #13 (permalink)
Old 05-03-2009, 10:03 PM
broncoman85 broncoman85 is offline
broncoman85 is starting off with a positive reputation.
Worked great on my wifes 07 MKX thanks thats been one of our major pains, she couldn't set addy while I was driving. Later Whit
__________________
Cut me and I'll bleed FORD BLUE!!!
  #14 (permalink)
Old 05-04-2009, 01:34 AM
nckracer's Avatar
nckracer nckracer is offline
nckracer is starting off with a positive reputation.
If anyone can figure out how to do this with the 2nd Gen Navigation on the 09's and newer, please let me know!
Thanks!
__________________
'09 Expy Limited EL 4X4
'05 F-350 PSD Crew 4X4
'02 F-150 KR Crew 4X4
'06 Taurus SES
  #15 (permalink)
Old 05-04-2009, 07:04 AM
wiingnut's Avatar
Quote:
Thanks!
no news yet. Look at the bright side, the only reason the oem's have these stipulations are because of the frivolous lawsuits the courts allow.
__________________
10 Escape XLT
Tags
fdevelop , nav , navteq , on
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
