Darkside calling Flathead carb options - Ford Truck Enthusiasts Forums
Old 12-22-2008, 10:34 AM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
Randy.. don't say a word...
Ok, I admit.. I hear the darkside calling. Since my flathead re-build is netting me some more HP via the Merc Stroker crank I was lucky enough to stumble on when my original crank came up cracked...
And my engine guy is REAL meticulous, he recently explained how Ford balanced the crank and the rods... and then how he is actually doing it. (He builds serious race car engines...)
Well, here's what I would like to do.
Keep the generator.. (this is the challenge)
And then go with a 2 carb set-up...
OR
If I can't fit two 2 barrels. then a 4 barrel.
Has anyone done this to their Flattie? Would love to see pictures...
Want to keep generator...so that impacts room... But I'm sure I've seen this done....
Any and ALL advice, help and specific detailed input is welcomed.
Steve
Old 12-22-2008, 11:54 AM
ssj7kids's Avatar
Some web surfing has shown that I can get a new manifold that will allow a 4 bbl, or 2 2 bbl carbs and still keep the generator....
I'm thinking that the 4 bbl would be easier to set up and maintain,
but the 2 2's would look COOL....
Any thoughts?
Old 12-22-2008, 12:16 PM
Scott123 Scott123 is offline
Scott123 is starting off with a positive reputation.
This is a side view of mine with a 390 Holley 4 bbl, with an alternator. However, you can see there's a decent bit of room between the two and most likely plenty of room for the generator. It's an Offy intake.
I know the twin carbs are the cool route, but I drive mine enough that I really appreciate the electric choke, and the relative ease of working on the Holley 390, plus the availability of parts for it. I don't even have to go the counter at O'Reilly, they have all the Holley carb stuff out in the store. There's also an adaptor to the 4 bbl intake to make it a twin carb set up, so you can switch back and forth if you want to try both routes, but linkages will have to be reworked too.
Old 12-22-2008, 12:39 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack has a good reputation on FTE.Randy Jack has a good reputation on FTE.
But...but...but? Why can't I comment?
(I knew you couldn't hold out forever!)
Old 12-22-2008, 12:42 PM
ssj7kids's Avatar
The force is strong with this one.....
Resistance is futile....
Randy, this is as 'dark' as I'm gonna go....
today.
Old 12-22-2008, 12:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Holley 94's and Stromberg 97's are $$$ in proper shape, and nothing to write home about even when perfectly dialed in. They didn't have sophisticated metering at all, so economy is not their forte'. Think about opening 4 butterflies instead of two, every time you step on the gas! (Sure you can stage them on some manifolds, but that's even more tricky).
Go with the 4-bbl, but check out Edelbrock's equivalent model. Lots of good words about it, and even better economy. No problems with power valves.
As far as clearing the generator, my recollection is some are running gen's with 4-bbls, but seems like there are some issues (maybe you have to mount the carb backwards?). What do the intake mnfr's say? I'd post over on the new Flathead Forum, I know guys over there have done it. Honestly, the alternator would do as much good as the 4-bbl!
Old 12-22-2008, 01:05 PM
ssj7kids's Avatar
Yeah Ross, once you start DOWN that slippery slope...... The darkside strangles you... LOL
If I switch to an alternator... I'm thinkin that then takes me to 12 V.. which then means switching everything over to 12...
I am still trying to stay stock. Hopping the engine is just my teenage years calling NOT THE DARKSIDE.... Luke... RESIST.
Old 12-22-2008, 01:41 PM
merten's Avatar
merten merten is offline
merten is starting off with a positive reputation.
Expensive but very cool Weber carbs. I would love to have this setup! And plenty of room for generator.
Old 12-22-2008, 02:14 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
The 2x2, 4bbl, gen relocation are all considered as Traditional Flathead. It's not even close to shades of gray let alone darkside.
Driving it everyday (or alot) I'd go the 4bbl route.
The Generator relocation is just a bracket that leans it off to one side to clean the manifold. Better yet get a Powergen which is and alternator thats build in a generator case.
Old 12-22-2008, 04:09 PM
ssj7kids's Avatar
Dick,
Do you happen to know if they make the powergen in 6V???
Merten, do you have a link for that?
Old 12-22-2008, 05:06 PM
-Jim G's Avatar
-Jim G -Jim G is offline
-Jim G is starting off with a positive reputation.
powergen
I found this Powergen link, but I know nothing about them: PowerGEN
Old 12-22-2008, 06:13 PM
ALBUQ F-1's Avatar
postin' fool
I'd be cautious with the powergen-type deals, I've heard they can't put out much without overheating (since the air flow is blocked)
Old 12-22-2008, 07:40 PM
merten's Avatar
Quote:
Weber Carburetors, Conversion Kits - Pierce Manifolds Inc.
LMC has the kits in their catalog too.
http://www.lmctruck.com/icatalog/fa/full.aspx?Page=35
Old 12-22-2008, 10:40 PM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
demon makes a 3 bolt carb for two and three carb setups
Old 12-23-2008, 03:37 PM
ssj7kids's Avatar
For those interested... Powergen does make a 6v positive ground unit. Chrome and black.
I'm waiting for pricing... Their website said O'Rieley's Auto had them, but the guys there didn't have a clue. Sometimes they're good... sometimes not so.
Would you define "Darksider" 54TexasF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 02-12-2012 09:44 PM
Really could use some help( darkside my F1 or not) Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 02-10-2012 08:01 AM
I am a complete Flathead newbie, so... havi Flathead V8 & Flathead 6 19 04-01-2008 03:35 PM
So Russ..... FFR428 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 06-07-2006 05:37 AM
Emptying fuel tank PigFarmer 1987 - 1996 F150 & Larger F-Series Trucks 3 02-28-2003 01:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
