Darkside calling Flathead carb options - Page 2 - Ford Truck Enthusiasts Forums
Old 12-23-2008, 07:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Quote:
Originally Posted by ssj7kids View Post
For those interested... Powergen does make a 6v positive ground unit. Chrome and black.
I'm waiting for pricing... Their website said O'Rieley's Auto had them, but the guys there didn't have a clue. Sometimes they're good... sometimes not so.
Summit has them... hold your breath!
Powermaster PowerGEN Alternators - summitracing.com
Old 12-23-2008, 08:06 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Come on Steve the darkside is calling for you. Them 12 volts sure do spin a lot faster when cranking the engine. Instrument lights are a little brighter to. I mine even donate any darkside extra parts I have.
Old 12-23-2008, 09:15 PM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
aw c'mon , mine is goin' completely 12 here real soon and despite wanting to retain the generator , which i have under the bench , and a really rough 12 volt one from that pos 1 ton i parted , im gonna stick with the alternator for a bit longer . i'd go 4bbl , and not no gawd darned rassa frassin ' *#@^+&#@%^ holley !!im gonna do another slightly " grey " thing and put a rochester 2 jet on mine and maybe use the 94 for batting practice ..........
Old 12-23-2008, 09:17 PM
merten's Avatar
merten merten is online now
merten is starting off with a positive reputation.
Yeah Ross, once you start DOWN that slippery slope...... The darkside strangles you... LOL
If I switch to an alternator... I'm thinkin that then takes me to 12 V.. which then means switching everything over to 12...
I am still trying to stay stock. Hopping the engine is just my teenage years calling NOT THE DARKSIDE.... Luke... RESIST.
Electric system of 12 volts does not darkside make.
Old 12-27-2008, 11:30 AM
cts1954 cts1954 is offline
cts1954 is starting off with a positive reputation.
I always have trouble copying pictures into a reply but there are a few good pictures in my gallery of my 52 flathead, 4" crank and dual Strombergs with the original generator converted to 12 volts. Have a look. I have got stalled working on it and need a boost or a boot.
Good luck
Old 12-27-2008, 11:33 AM
ALBUQ F-1's Avatar
postin' fool
Quote:
Good luck
The key to gaining clearance for a gen is to stay away from "Super Dual" manifolds. They position the carbs more evenly over the intake ports, at the expense of clearing the gen. But, the 4-bbl is still a better option.
Old 12-27-2008, 11:57 AM
Ross
Thanks for posting the picture. I was going more for the looks than performance.
Old 12-27-2008, 12:05 PM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
That engine is COOL...
I was talking to my engine guy and he thinks we should go with 3 2's. He will set the linkage up to run on the middle one, until you goose it for higher RPM's. I too am looking at looks, as opposed to performance. I'm NOT gonna be racing this thing... and at the local cruise in, you just sit there with the hood open.... The 3 2's will work (or so I've learned in my research) with an offset bracket for the generator.
What type of headers do you have on there?
Old 12-27-2008, 12:11 PM
Steve
They are Sanderson center dump headers with a ceramic like coating, they look good but were a pain to put on. I had to replace the oil dipstick with a Lokar model and it had to be modified to work. I like the 3 carb set up as well but I don't like the alternator adaption even though it would work better.
Would you define "Darksider" 54TexasF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 02-12-2012 09:44 PM
Really could use some help( darkside my F1 or not) Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 02-10-2012 08:01 AM
I am a complete Flathead newbie, so... havi Flathead V8 & Flathead 6 19 04-01-2008 03:35 PM
So Russ..... FFR428 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 06-07-2006 05:37 AM
Emptying fuel tank PigFarmer 1987 - 1996 F150 & Larger F-Series Trucks 3 02-28-2003 01:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
