NAKED WOMEN - Ford Truck Enthusiasts Forums
NAKED WOMEN
Old 05-29-2001, 01:17 PM
78f250 78f250 is offline
78f250 is starting off with a positive reputation.
NAKED WOMEN
Old 06-01-2001, 02:15 AM
cubster cubster is offline
cubster is starting off with a positive reputation.
NAKED WOMEN
Hope this got someones attention. I own a '91 x-cab 2wd Ranger that is lowered 6" in front and 6 3/4" in the rear. Can anyone tell me if my driveshaft is too long for this in the long run? And also, can I please get a hint on what degree shim to correct my pinion angle? Thanks in advance.
Old 06-02-2001, 12:39 AM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
NAKED WOMEN
To my deepest shame, I must admit you got my attention.
Regarding the driveshaft. I assume you have driven it since it was lowered. In that case put it up on a lift and see if the wear marks on the front of the driveshaft, from the tranny seal are still a little ways from the flaring of the driveshaft. In any case I would plan on replacing that seal when it starts leaking since it will wear down the dust and rust on the shaft at the expense of the seal. You would know real quick if the drive shaft is too long by the failure of the seal or hammering of the shaft against the tranny housing.
Your other ? Sorry, I was distracted by a short skirt and don't remember what it was. :7
98 F250LD 4X4
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 11:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 08:56 PM
Tags
150, big, cars, diesel, f150, f250, ford, naked, nude, platinum, superdutys, truck, trucks, woman, women
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
