2002 7.3 cold start loping
Diesels hate the cold. My 2002 7.3 is no different and noticed a pretty extreme loping upon start up last winter. This was after I had service (complete fluid drop & refill) done to the truck and the tech refilled the crankcase with kendall. I use chevron delo so changed it out. Nothing like it was but still a little this winter. Any ideas?
You might also want to consider installing a high-pressure cross-over (HPX) line. It ties both high-pressure oil rails together to improve High-Pressure-Oil-Pump (HPOP) pressure regulation performance.
Consider the non-flexible stainless-steel-line type.
It doesn't cure it completely, but it helps eliminate it under most circumstances.
Pop
Pop
Cycle the glow plugs a few times before starting it. Bear in mind the glow plugs stay on much longer than the "wait to start" light. Depending on temps, let the glow plugs cycle 2-3 times (even more for really cold weather) for 60 second intervals before cranking. You can also plug in your block heater to help on cold starts. Most folks find using a heavy duty timer helpful (15amp variety) because the block heater only needs 2-3 hours to heat up to be effective, any more time than that and you're just burning electricity.
It would also be good to verify that your glow plugs and glow plug relay are working properly to give your truck all the help it needs to fire up in the colder temps.
In all of the 7.3's that I've worked on recently - if there's a glow plug drawing extreme amperage (not working/improperly working) it's not long after that I'm back in and changing out injector harness as well.
In that case, what can I expect to pay for changing out all 8? If doing one, might as well do all with the 7.3 track record.
i changed all 8 last year in my 99, was real easy to do, other than a little bit of cussing.. i think i paid around 8$ per plug, for zd-11's (i think thats right) i done my research here first, but it was easy enough to do, just took a couple hours. if you take it to a shop I dont think they could get away with charging more than 2-3 hours labor, but watch their parts price, thats what'll get ya, and i bet an experienced tech could prolly do it in 1.5~2 hours easy.
