sandwich oil cooler
sandwich oil cooler
I thought I was going to have my snow plow project ready for the first snow. Well in the past threee days we've had two snow storms with around 20" total accum. The day before I buttoned everything up and was ready to go. I put in coolant and then coolant leak...... Its a 96 F250 with a sandwich style oil cooler between the block and the oil filter. It has two ports that connect to the lower radiator coolant hose. The "sandwich" block has sprung multiple pinhole leaks. Where can I find an aftermarket product? Also, I havn't got a good look at it yet because I need to pull the pwr steering bracket off. How do I remove this sandwich block. Is it bolted on? Or Is is screwed onto the oil port? Or both Or neither. Is there any thing else I should order when buying a new one...o'rings, screws ect...
Any help much appreciated.
96' F250 5.8L
96' F250 5.8L
How To remove oil cooler
I don't see any fasteners. I think it either screws on in one piece or you unscrew the main oil port in the center and the whole thing sits on a big o ring.
Also, do you see the little pits on the top of the cooler? Those are the pin hole leaks. This rusty motor has nickel and dimed me to death. I wish I bought a complete motor when I first bought the truck.
This is my first rebuild, I don't even know if the beast is going to start/run. I wonder if I should just jbweld the cooler and see if the motor starts. If I could get a year out of it, I could justify buying a new cooler in the spring.
Part from Ford $210 After Market ftepartsguy 89
My big fear is taking it off this rusty motor and potentially damaging the seat which may mean buying the a whole block.
Opinions?
Opinions?
Opinions?
Opinions?
F4TZ6A642A cooler list $236.73 sell $ visit my site, but it's not $89 and I sell factory OEM Ford parts.
Ed
A lot of the billet aluminum ones route the oil out of the engine, to a cooler, then back to the filter. I don't know how the stock adapter works, but for some reason I was thinking that it was the heat exchanger and that coolant was passed through the adapter on its way to the water pump inlet. If that's the case and the stock adapter/heat exchanger got replaced with an aftermarket billet one, you would have oil and coolant mixing and that wouldn't be pretty.
The stock adapter looks pretty easy to remove, with that hex cut into the center of the bolt/stud. You could temporarily get a straight fitting to thread into the block which would also mount the oil filter and just remove the adapter entirely until you can afford to replace it.
stop leak
Has anyone had success using one of those stop leak products. I was talking to a friend last night and he told me he has used some "powered copper" stuff over the past 20 years and he says it works.
Because I love bubble gum and bandaids, I leaning on that stuff with some jbweld on the exterior.
you are just masking a problem that will more then likely come back to bit you at the most inopportune time.
fix it correctly imho.
Oil cooler removal
Dont remove the oil cooler, I did this and ended up with no oil pressure. There are check valves in the cooler I was told.
