1960 taillight question
Old 12-20-2008, 06:26 PM
my my 289's Avatar
my my 289
my my 289 is offline
Maybe someone can answer this. What do I have here? These came off of my truck. (A) has TRST-57R stamped on the back. (B) has TR-57 stamped on the back. I also have 1 melted taillight lens. I'm assuming that I need another (A), but I'm wondering if the (B) is for a front turn signal on a 57-58. On the first pic there is a bulb in each light. Also, was there an original lens made out of glass maybe that used (B)? Thanks for any help!
Old 12-20-2008, 11:45 PM
Tomget's Avatar
Tomget
Tomget is offline
tail lamps
I'm not 100% on this and I've got a 58 styleside. And I have two of the "A" style "buckets?" right here in front of me, if that's what one would call them. And one is stamped TRST-57B with the little script Ford logo, and the other looks almost exactly the same, but has the 5 total holes arranged slightly differently and it has no stamping whatsoever. These are some extras and I've got four mounted on my 58 and as look underneath in the front--rear's not so easily accessed, I see that they are also of the "A" style. I've never looked so closely at these buckets until now. And I wasn't aware there were any differences-- I thought they were all "A" style, but that doesn't mean they are--it just means until you asked I never noticed any difference. I guess if you can get them to fasten--the B style that is--I guess it wouldn't make any difference. The second part of your question regarding "different glass" lenses etc. I don't know anything about that. I've got the round plastic lens-red in the rear and somewhat clear in the front. The lenses are available from the aftermarket. I don't see off hand that the buckets are available--they may be I just don't see'm.
Good luck tom
Old 12-21-2008, 12:00 AM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
Received 1,340 Likes on 1,102 Posts
I`m not totally sure about this but I think that the 60 Econolines might be similar and just might work.
Hopefully someone can confirm or state other wise this if it`s not right.
Old 12-21-2008, 06:25 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Send a PM to Col. Flashman! He'll have an answer for you.
J!
Old 12-22-2008, 04:18 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B is not a parking/turn signal lamp body.
The parking lamp bodies have a different outer bezel which has a "chrome like" finish, the lens fits inside it.
1957/60 F100/350 Styleside: These taillamp bodies are right/left specific:
B7C13434A .. Right Taillamp Body / B7C13435A .. Left Taillamp Body
TRST-57R: R = Right. The other body is prolly a left.
Why are they different? I dunno.
1961/64 Econolines & 1961/66 Styleside pickups (that used the 57/60 bed) used a similar lamp body, but it is not the same.
C2TZ13434A .. Taillamp Body-Right and left are the same.
None of the taillamp lenses were glass as original.
What someone may have done is used a glass lens from a 1928/36 Ford car, or the glass lens is a gypo (aftermarket) replacement.
What are the DOT markings (if any) on the glass lens, and on the plastic lenses?
Old 12-22-2008, 05:01 AM
crazedfox's Avatar
crazedfox
crazedfox is offline
Hey,
__NumberDummy. When do you sleep?
I see you answering at all hours mostly.
Old 12-22-2008, 07:51 AM
my my 289's Avatar
my my 289
Thanks all for checkin it out. But let me clarify it a little. I have plastic lenses and the one on (B) melted because the bulb was touching the lens. I bought a new set of plastic ones but don't really want to melt this one too. I thought maybe there was a glass lens that I could get away with, but it looks like I might be heading to the junkyard soon. Looks like I'm better off finding another (A). Still doesn't explain where (B) came from. Pretty strange I think.
Old 12-22-2008, 08:38 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
You can usually slide the light socket deeper into the assembly, most are just pressed in. Might have to drill out a spot weld first.
Old 12-22-2008, 08:59 AM
NumberDummy
If B isn't the left side, then it's C2TZ13434A, the body used on 1961/64 Econolines & 1961/66 Stylesides w/the 57/60 bed.
I went by the pics in the parts catalog, the C2TZ and B7C bodies look identical.
crazedfox: Like rust, I never sleep.
Old 12-23-2008, 02:51 PM
chloichina's Avatar
chloichina
chloichina is offline
B would look great with a Pontiac lens crome outter and a cadillac bullit lens center. people could see it better from the side.
Old 12-23-2008, 07:43 PM
my my 289's Avatar
my my 289
1961 Ford E 100 Spray In Bedliner Photo
Would anyone know what this guy used for taillights? The article says mid fifties car.
Old 12-24-2008, 01:22 AM
NumberDummy
If the owner of that Econoline pickup ever needs replacement taillamp lenses, he'll never find them on any 1950's car, because.....
They're from a 1961, as Dinah Shore used ta croon: "See the U S A...in your Chev-rolet."
ken selvy
1059
02-09-2023 08:16 AM
sofob0909
06-14-2016 02:50 PM
pbStriker38
51
06-27-2009 08:27 AM
Greywolf
Testing.....
05-15-2009 05:38 PM
ksmith203
15
02-13-2007 09:51 PM
Quick Reply: 1960 taillight question
