Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Nevada Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nevada Chapter Join Chapter, Leader:67 Olfthfl
  #1 (permalink)
Old 12-20-2008, 11:53 AM
cburch cburch is offline
Garage is empty, add now
cburch is starting off with a positive reputation.
4WD Not Engaging
Tried to turn on the 4wd during the snow this week. The light on the dash would not light up. I locked the hubs in manually, not sure if that supplied power to the front wheels or not. From researching the issue here on the forums it sounds like this could be a vacuum issue. I will look into this. If anyone has any experience with this I would be grateful to hear from you.
Did I have power to the front wheels by locking the hub in manually???
Clint
  #2 (permalink)
Old 12-21-2008, 02:51 PM
racerchick21's Avatar
racerchick21 racerchick21 is offline
2000 Ford F-250
racerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to beholdracerchick21 is a splendid one to behold
I'm having the same problem ! To answer your question though, even if you locked the hubs manually, you won't have power unless the transfer case is engaging, which it probably isn't if the light's not coming on. I'm assuming you have ESOF and not a manual shift TC. A vacuum problem will keep your hubs from enaging (hence the manual option) but the TC is shifted by an electric motor, not vacuum. What kind of truck do you have?
__________________
I thought I wanted a career. It turns out I just wanted pay checks.
2000 F-250 XLT Lariat 4x4 SC V10 6" lift, 35" tires, Powerdyne supercharger, K&N filter, Gibson headers & exhaust, Tugger shift kit, Billet lockup torque converter, on board compressor, Leer shell, various flame themed accessory doo-dads and TUNES!
  #3 (permalink)
Old 12-21-2008, 08:46 PM
I have a 2000 Excursion 4x4 7.3 Diesel Limited. I think I have basically eliminated everything except for possibly something electronic. I put a vacuum on the hub at the rotted vacuum line and the hub assemblies at both sides were holding a vacuum. I am thinking that the electric motor and switch at the transfer case might be the issue. Or possibly the switch at the dash. I am going to pull my tester out tomorrow and check. I will let you know what I come up with. Hopefully one of us will be able to find the problem and help out the others.
  #4 (permalink)
Old 12-21-2008, 08:48 PM
whoops. I put the vacuum at the hub assembly where I replaced the rotted vacuum lines. The vacuum held for 15 minutes plus. So, I am thinking that all the seals at the hub are working. ( however, I think I may have a leak in the outer axle seal, finding a bit of oil gathering up there, nothing to do with the 4wd though...)
  #5 (permalink)
Old 12-22-2008, 09:49 AM
jarod17's Avatar
jarod17 jarod17 is offline
1994 Ford Mustang
My Garage
jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.jarod17 has a very good reputation on FTE.
I would have to say it it probably your electric shift TC. My cousin had the same problem with his Bronco. He finanly got tired of the motor going out and converted to a Manual shift TC. Good luck.
__________________
Jeff
  #6 (permalink)
Old 12-22-2008, 12:30 PM
2000 Ford F-250
We solved the hub engagement problem by replacing the vacuum switch (not sure if you call it a switch, little plastic thingy that the lines go into) under the hood, it was full of crud. If it's something simple let me know! I suspect my problem has something to do with the ECM, if that's not working right it will manifest itself in all kinds of odd ways. Before the 4wd quit working it would shift in and out on it's own. I'm looking for a wiring diagram so we can start eliminating some things.
__________________
Tags
2000, 2007, 250, 4wd, drive, engaging, excursion, f150, f250, ford, manual, quit, shift, wheel, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
