2002 F250 Rear End Rebuild - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-20-2008, 10:50 AM
YellerMax's Avatar
YellerMax YellerMax is offline
YellerMax is starting off with a positive reputation.
Please advise on a few things:
1. I recently had the pinion bearing replaced, and now the truck whines loudly at certain speeds. I've heard mixed answers on whether I just need new gears for it or a complete rebuild kit with another new pinion bearing and gears. I just want to get rid of this awful whine. Any ideas?
2. I'm trying to find the original rear end gear ratio. The vin sticker is partly illegible.... Whats the next step?
3. Any recommendations on brands of gears and/or rebuild kits?
Thanks!
Old 12-20-2008, 12:08 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Firstly take it back to shop who did the pinion bearings. They need check the mesh again. As long as the stock gears weren't damaged, they should be as quiet as they were before. However if they did get scarred/marred or any other term you can think of, then it would be best to replace the gears. AAM is one of the bigger gear manufactures, they produce gears for motive, yukon, GM, Ford, and many others. However there are levels to the gears and those level determine how noisy they are. Richmond got a rep a few years ago for being noisy, Motive's Performance Line has been good for me. Yukon and precision gear have a decent rep as well.
Old 12-20-2008, 12:11 PM
ReAX's Avatar
Quote:
There was a tag on the diff as well. However, if you jack the rear up and spin the tires you can count rotations. Mark the tire and the drive shaft, count howmany times the driveshaft rotates for a full rotation of the tire. Normal ratios are 3.73 or 4.10, so either the DS will spin just short of 4 times or 36 degrees more than 4 times.
Old 12-20-2008, 01:42 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Stock, your truck came with a 3.73, 4.10 or (FAIRLY RARE) a 4.30 gear ratio.
I agree, you should take the truck back and have the shop that installed the new pinion bearing check their work. It may be as simple as a failing U-joint.
Old 12-20-2008, 05:02 PM
23larry24's Avatar
23larry24 23larry24 is offline
23larry24 is starting off with a positive reputation.
I too agree that you should take it back, They may have incorrectly installed the pinion bearings by tightening them with a impact gun, which will destroy the new bearings in short order. While they have it apart just ask them to check the ratio.
Rear End Whine F150MUTT 2015+ F150 7 01-20-2017 11:21 AM
whine on acceleration? esten07 2004 - 2008 F150 1 11-15-2015 02:06 PM
Differential Whine jeffnick 1968-2013 Full Size Vans 3 03-21-2015 02:21 PM
sterling 10.5 rebuild? powerstroker02 1999 to 2016 Super Duty 3 10-01-2012 03:35 PM
whine in new ring and pinion rear gears painintheneck Clutch, Transmission, Differential, Axle & Transfer Case 3 09-28-2007 12:41 PM
Tags
2002, 250, 430, axle, elizabethton, end, f250, ford, gears, rear, rearend, rebuild, rebuilding, replacing, tn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
