how to shift without clutch
a comment in another thread got me thinking...
when i first got my truck, a friend jumped in and drove it around and didn't use the clutch. he said it was a combination of RPM's, speed, and touch.
i can sometimes find my way out of the higher gears without the clutch, but never can i find my way in to any of the gears.
what is the secret?
what is the secret?
Think about it why don't the big rig drivers use a clutch and racers, it wastes energy and time.
The key is to never let your foot totally off the acc. pedal, use it to control the rpm on the motor whether you are in gear or not. When up shifting let off a little and pull the stick out of gear(it should come easily otherwise you are not maintaining the rpm right) don't completely let off the gas, push the stick to the next gear while allowing rpm's to drop controlled, when the stick gets the gear it will grap it and pull it in almost, accelerate until it is time to shift again and start at step one.
To downshift you do just the opposite of upshifting in between gears, instead of allowing the rpm to drop you rev the engine to the desired rpm for the down shift, alot of times you can apply slight pressure at the gear you are trying to get while easily reving the engine, and again when you hit it right the gear will almost grap the shifter and pull it in.
Hope that helps.
There are advantages to not using the clutch also esp. while towing. If youi get the hang of it and get it smooth you can shift gears pulling hills and such with a load and not loose as much speed and momentum.
Hope that helps.
Hope that helps.
When I first tried it I started on the 4-5 shifts. It seems easier on the top end. Watch the speed and RPM when in 4th, push in clutch and shift. Watch what speed and RPM's when it first goes in 5th. Then replicate it without the clutch. work your way down to 1st and 2nd.
Yea, syncro's are to help newbie shifters not shift without the clutch.
Most truck drivers hate them, cause they are used to just being able to shift when they want, and not worry about rpms.
Tim, what are you talking about not using a clutch?
Have you not tore appart an auto? There are several clutches in there.
It's an awful handy skill for driving older trucks. WHen the clutch goes, there's still a way to get where you need to. My wife gets ticked off at me for doing it, but whatever. I started driving in an old '54 IHC pickup without syncros and quite honestly, it was easier to drive without the clutch on that thing. Also, when I was driving big rigs (again, old beaters), it was just easier. Once you know your machine. I even do it in my '04 Corolla sometimes.
1990fordf-250
12-21-2014 05:41 PM
dyingtolive
15
03-29-2012 11:56 PM
