Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-20-2008, 07:46 AM
OzFTrucker's Avatar
OzFTrucker OzFTrucker is offline
OzFTrucker is starting off with a positive reputation.
What is the largest capacity Y block you can biuld?
What is the largest capacity Y block that can be built and what parts would be needed to accomplish this?
__________________
The right side is the RIGHT side for the steering wheel.
  #2 (permalink)
Old 12-20-2008, 12:35 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 is starting off with a positive reputation.
First off you will need a THICK wallet! I think 341 cubes is the largest but I'm not sure.
Kevin Bigwin
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #3 (permalink)
Old 12-20-2008, 05:47 PM
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Go to Y with notebook and calculator ready. Blue Thunder intake port matched to heavily worked G, 113 or the aluminum heads that are due out soon. Off the top it sounds like an 8k engine .
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #4 (permalink)
Old 12-22-2008, 03:13 AM
pcmenten pcmenten is offline
pcmenten is starting off with a positive reputation.
For a block I'd be looking at ECZ-C, EDB-E, and B9AE-F blocks. They'll need to be checked for cylinder wall thickness. A quick check you can do is to pull the freeze plug that's behind the starter and check to see if that last cylinder tilted during casting. That's the one to give you trouble if there's going to be excessive core shift. You'll see the tilt visually by looking at the gap between cylinders. I've heard that you can sometimes get a 3.912" (Dodge 318) bore.
I've heard that you can use a 351 crankshaft. I would think that the Cleveland crank would have slightly lower profiles on the counterweights, so consider that. Obviously, you'd have to find a crank grinder willing to turn that into a y-block crank. Offset grind it to a 3.65" stroke with 2" journals for the long Chevy rods.
John Mummert can source the long Chevy rods.
That's 350 cubic inches. I have to wonder if the heads would support anything bigger.
__________________
Best regards,
Paul Menten
  #5 (permalink)
Old 12-30-2008, 10:04 PM
yalincoln2 yalincoln2 is offline
yalincoln2 is starting off with a positive reputation.
hi, the old engine builders used to say 3.64 was the limit on stroke because of cam location. bore's, if you find a thick block you can go to 3.935 chevy 307-.o60 over. i've heard of a couple guys who went to 4.00 in. but they don't live long. they don't recommend going over 3.875 if your going to crank any RRRRRRRR's, and then you should sonic check for core shift.
  #6 (permalink)
Old 01-01-2009, 03:20 PM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Boy, there sure is a lot of " I've heards", "ifs", and "theys" in this thread... ha,ha
Happy New Year, Guys
Y-Blockhead
  #7 (permalink)
Old 01-05-2009, 09:13 PM
Arno F100's Avatar
Arno F100 Arno F100 is offline
Arno F100 is starting off with a positive reputation.
I talked to John Mummert about my 272 block
I,m sure u can make a 310 of it with 3,47 stroke and 3,77 bore.
Some forged pistons with 10cc dome for higher compression, bigger intake valves, 1,54 rockers, 4bl intake, ramhorns and of you go.
It is possible to increase stroke to 3,7 and that makes 330, but check out your rod clearance because of the larger cirkel they make.
  #8 (permalink)
Old 01-05-2009, 11:02 PM
Have you ever thought about why the Ford Y's, especially those in trucks, have lasted so long?
Bullet proof block, large rod/main journal overlap, light spring pressures on mild cam, low rpm torque allowed by small intake runners and valves, low rpms, low compression ratios producing minimal strains... How long do you think a big stroker Y will last? Big decrease in journal overlap, high spring pressure, high rpm, high CR, ... Just for consideration.
__________________
1990 Ranger 4WD
  #9 (permalink)
Old 01-06-2009, 02:58 AM
Arno F100's Avatar
In my opinion a stroker engine is designed for low end torque and max rpm of 4000.
That way it will last a long time i think. But if you look at some dyno tests, they go up to 7000 rpm. That's no good to any engine.
  #10 (permalink)
Old 01-08-2009, 08:04 PM
Agreed. I have a 312 crank newly ground for 292 mains, which would be 318. If it ever gets done I would keep the rpm below 5K. Cant help being chronically conservative.
__________________
1990 Ranger 4WD
  #11 (permalink)
Old 01-08-2009, 11:27 PM
Mike,
Who did the crank grind?
I know of a local crankshaft shop that has a fancy lathe, and he does offset grinding, etc., but I haven't tried him out yet to see the quality of his work.
__________________
Best regards,
Paul Menten
  #12 (permalink)
Old 01-08-2009, 11:58 PM
Paul,
It is a semi secret shop in Eugene, OR. The local machinists here use them and are reluctant to release their name. Doesnt even appear on the invoices. I think they have a lot of business from all over, Portland, Salem, maybe even into WA, with a guy making regular trips picking up cranks and delivering same. Not even any charge for shipping. I could most likely find out if anyone is really interested. But they are GOOD, and were one of the rare outfits able to grind down the rear main seal journal while leaving the oil slinger.
The same outfit did some rod work for me on this current engine. The rods were resized, balanced, bushed, and all of them came out .004 shorter than stock, which is an amazing and rare feat when you look at any stock rods, rebuilt or not. Lengths are generally plus or minus .003 or more. I told them the block would be zero decked, and rods should end up as long as possible, so they went the extra mile.
Mike
__________________
1990 Ranger 4WD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
